Kevin Plaul
Flex 4.3 AdvancedDatagrid Problem
Jul 15, 2013 11:19 PM
Tags: #error #bug #event #key #advanceddatagrid #f8 #strange
Dear Community,
i have a strange problem with the AdvancedDatagrid in Flex 4.3. It is a simple Datagrid without any Eventhandler and so on. If i have less Rows i dont have a Problem. But if i have many Datarows (in my case about 2000) and than i press the F key, it selects a row. But why?
Now it comes really strange:
if a add an eventhandler that listen to the F8 Key, the Datagrid selects any Row BEFORE it throws my added event.
    Jul 16, 2013 3:37 AM   in reply to Kevin Plaul
    Can you share a sample code?
    Jul 16, 2013 6:56 AM   in reply to Kevin Plaul
    Kevin,
    I would like to see more of your code, no data.
    Best,
    Jul 16, 2013 8:40 AM   in reply to Kevin Plaul
    I don't have flex 4.3 anymore, i am using Flash builder 4.7 with SDK 4.5.1.
    Try taking out selectionMode="singleRow" and designViewDataType="flat"
    Jul 17, 2013 4:16 AM   in reply to Kevin Plaul
    Here is my solution:
                   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="init()">
        <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
        </fx:Declarations>
        <fx:Script>
            <![CDATA[
                import mx.collections.ArrayCollection;
                import mx.controls.Alert;
                [Bindable]
                private var dpFlat:ArrayCollection = new ArrayCollection([
                    {Territory:"Arizona", Territory_Rep:"Barbara Jennings", Actual:38865, Estimate:40000},
                    {Territory:"Arizona", Territory_Rep:"Dana Binn", Actual:29885, Estimate:30000},
                    {Territory:"Central California", Territory_Rep:"Joe Smith", Actual:29134, Estimate:30000},
                    {Territory:"Nevada", Territory_Rep:"Bethany Pittman", Actual:52888, Estimate:45000},
                    {Territory:"Northern California", Territory_Rep:"Lauren Ipsum", Actual:38805, Estimate:40000},
                    {Territory:"Northern California", Territory_Rep:"T.R. Smith", Actual:55498, Estimate:40000},
                    {Territory:"Southern California", Territory_Rep:"Alice Treu", Actual:44985, Estimate:45000},
                    {Territory:"Southern California", Territory_Rep:"Jane Grove", Actual:44913, Estimate:45000}
                private function init():void{
                    myADG.addEventListener(KeyboardEvent.KEY_UP, keyHandler );
                private function keyHandler(event:KeyboardEvent):void{
                    if (event.keyCode == 119 && event.charCode == 0)
                        Alert.show ("F8 key");
        </fx:Script>
        <mx:AdvancedDataGrid id="myADG" editable="false" width="100%" height="100%" dataProvider="{dpFlat}"
                             sortExpertMode="true"
                             selectionMode="singleRow" >
        </mx:AdvancedDataGrid>
    </s:Application>
    Jul 17, 2013 6:42 AM   in reply to Kevin Plaul
    Did you actually try my code?
    If you have other issue please add you code to this example because I don't understand your issue.
    Best,
