Yvonne-S.U
When PC starts up, error: RegSvr32, The module C:\users\....\appdata\local\Adobe\sbbqapgn.dll
Jul 16, 2013 2:56 AM
When PC starts up, the following error is shown:
RegSvr32, The module C:\users\....\appdata\local\Adobe\sbbqapgn.dll may not be compatible with the version of Windows that you are running. Check if the module is compatible with an x86 (32-bit) or x64 (64-bit) version of regsvr32.exe
OS: Windows 7 32bit
Acrobat Reader X
I have the same installation, the dll file is not on muy or any other machine I checked so far.
    Jul 16, 2013 3:07 AM   in reply to Yvonne-S.U
    Adobe Reader does not install DLL files in the application data of users. May be that this files comes from an virus.
    Jul 16, 2013 5:53 AM   in reply to Yvonne-S.U
    Virus scans doesn't found all things.
    Run msconfig and remove this entry from the startup tab.
    Jul 16, 2013 6:43 AM   in reply to Bernd Alheit
    That sounds normal if you just deleted the file rather than whatever caused it to load. Sounds as if your virus scanner isn't doing its job. Still, that error message is much better than having the virus.
