Acrobat Pro Does Not Install
Jul 16, 2013 12:51 PM
We are using TCS 4 on a Windows 7, 64 bit platform.
When we installed TCS 4, we did not get Acrobat X Pro (nor XI).
So, I inserted the installation DVD to see if I could just install Acrobat Pro, and the Adobe Installer would not proceed because it detected an installation of TCS 4 already.
So, I uninstalled TCS 4 (a 30 minute ordeal), and proceeded to install it all over again, this time hoping to verify that Acrobat Pro was, in fact, selected in the product check list.
In the product check list, Acrobat X Pro was indeed selected in the product check list. Installed it all over again (another 30 minute ordeal).
Saw the statement: Installing Acrobat X Pro.
When the installation was done, saw the following: "Some items for the following product(s) could not be installed successfully." (PDF icon)
Acrobat X Pro did not show up under programs, by itself, or in the Control Panel (Programs and Features).
Went here for update:
http://helpx.adobe.com/tech-comm-suite/kb/tcs-4-update1.html
Saved zip file to hard drive. (A 549 MB download.)
The Installation Instructions were in a PDF, which my system could not read since Acrobat X Pro did not install.
Followed instructions on URL above.
Double-clicked "Set-up.exe" in the unzipped files.
Adobe Installer hung up at about 2/3 of the way through "Initializing Installer" (it stops dead).
Anyone have any ideas?  Thanks!
    Jul 26, 2013 11:44 AM   in reply to TimLMun
    Were you a local admin user when you tried to install this? Did you have a prior version of Acrobat already installed? If so, it needs to be uninstalled first before trying to load the Acrobat X version that comes with TCS4 (the upgrade to XI should process smoothly once X is installed). You'll probably have to start again & scrub out all parts of TCS4 - try using Revouninstaller (free tool) that does a great job of removing hard-to-delete apps.
