Output Module (Bridge CC) not working on Mac
Jul 17, 2013 3:28 AM
Tags: #mac #output_module #bridge_cc
As suggested here
http://helpx.adobe.com/bridge/kb/install-output-module-bridge-cc.html
I downloaded and tried to install the Bridge CC Output Module. I could not find the "Bridge CC Extensions" folder only "Bridge CC"
I can see the output name inside Bridge when I try to install it but nothing happens when I try to click it, it's just greyed out
I using Bridge 6.0.0.151
On OS X 10.8.4
  • Omke Oudeman
    Nov 27, 2004
    Jul 17, 2013 4:33 AM   in reply to Abysmal_85
    That's because you are looking in the wrong library. Your screenshot shows content of the user library (the one in your user account itself and hidden by default per OSX 10.7)
    You have to be in the library at root level. In Finder navigation column select the hard disk where your system is installed on e.g.: Computer/ Macintosh HD (but this is the default, if you have a custom name select the start up disk where your system is installed on.
    There you will see:
    -Library
    -Users
    -Applications
    -System
    Choose the upper one: Library / Application Support / Adobe and inhere is a folder called 'Bridge CC extensions'
  • Omke Oudeman
    Nov 27, 2004
    Jul 17, 2013 6:28 AM   in reply to Abysmal_85
    But that still only leaves it blank
    I'm sorry to hear that and I don't know a solution to this problem. As I am on a Mac (10.8.4) to and have no problem with installing and using AOM it is a strange problem.
    Be sure to have tried all solution give in the Adobe KB document (double check on the correct locations and correct folders.
    And here is a copy of the tips I gave in an other thread to try also:
    Also delete the Bridge6 Plist file (com.adobe.bridge6.plist) from the preference folder in the user library before again reset the prefs voor Bridge with option key on restart.
    Download the zip file again and install it again, overwriting the older files.
    Also reset prefs and workspaces in CS6 Bridge.
    Jul 17, 2013 4:59 PM   in reply to Abysmal_85
    I am having the same issue. Any chance you got this working?
    Jul 19, 2013 1:12 PM   in reply to Abysmal_85
    See if you can figure out if there are programs at home, that you do not have at work,  that might conflict.
    Jul 20, 2013 11:09 AM   in reply to Abysmal_85
    You may have found the vital Link.
    The replacement AOM for Bridge CC installed without any problems and works perfectly here on OSX 10.8.4 -- but I also have CS6 installed on the same machine.
    Try re-installing CS6 and see if the Bridge CC Output Panel then works.
    My guess is that a vital component in Bridge CC is missing and suggest that  Adobe need to post a completely new Update on the Cloud for Bridge CC (with a properly integrated AOM incorporated into the Build).
    The current idea of  offering the AOM as an add-on has proved to be far too difficult and burdensome for the average User to handle.
    Jul 20, 2013 2:53 PM   in reply to Abysmal_85
    Uninstalling CS6 after installing CC is bound to damage the CC installation.  The two versions have way too many similarly named components in similar places.
    Jul 21, 2013 7:59 AM   in reply to station_two
    Just to reinforce what station_two is saying.  If you want to install CS6 after your CC installation it is best to uninstall CC, install CS6, then install CC.  Normally the last version sets preferences for such things as file associations.
    Aug 28, 2013 10:12 AM   in reply to Curt Y
    their directions are very confusing.
    I ended up figuring out how to install the panel by mimicking the way it looks in the CS6 Extensions folder:
    So the folder included in the download goes in the "Extensions" folder level, NOT within "Workspaces".
    Then everything snapped into working (for me).
    And like a previous poster said, it needs to be installed in the System > Library > Application Support > Adobe > Bridge CC Extensions folder.
    Dec 19, 2013 3:07 PM   in reply to dwintonkalisher
    I go to all of these folders but once I get to Adobe >  There is just a "Bridge CC" folder, not a "Bridge CC Extensions" folder... and this is not working for me at all.  Got on chat, that was (as always) the biggest waste of two hours of my life.  I'm about to scream.
  • Omke Oudeman
    Nov 27, 2004
    Dec 19, 2013 3:28 PM   in reply to morganj_8
    That is because you are looking in the wrong place or wrong library.
    See the screenshot in post 7 from this thread for correct location:
    http://forums.adobe.com/message/5855431#5855431
    Apr 11, 2014 2:03 PM   in reply to dwintonkalisher
    Ty dwintonkalisher, this work perfectly.
    After much aggravation and many hours of trying to get output on bridge so I can finish the text book lesson for my PS class, this was the piece of advice that got it to work.
    I tried everything downloading the AOM, moving the workspace and module folders to the extension folder, resetting the workspace and so on, over and over. Then Google for answers I found this thread.
    I am working out of the correct folders for windows.
    Program files>Common file>Adobe>bridge extensions
    I know most are working with Mac's but I think this very simple fix will work for both, and its so obvious I don't know why they don't just update the instructions to tell us.
    PUT THE AdobeOutputModule.workspace FILE IN THE WORKSPACE FOLDER!!
    It would save us all a lot of aggravation, thank you for the help it was all I had to do to make it work just fine.
