Adobe Photoshop CC has stopped working
Jul 17, 2013 7:40 AM
Tags: #windows #not_working #stopped #cc
Installed CC photoshop on a brand new W530 laptop.
Upon launching either the normal or 64 bit versions of photoshop CC, the application loads then I receive the following error...
"Adobe Photoshop CC has stopped working"
I am unable to use the application, I have removed and reinstalled also in an attempt to correct the issue.
investigation of the event log results in the error below.  Has anyone else seen this ?
Log Name:      Application
Source:        Application Error
Date:          7/17/2013 9:24:12 AM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      TAG004144.tagusa.com
Description:
Faulting application name: Photoshop.exe, version: 14.0.0.0, time stamp: 0x51763d4f
Faulting module name: nvd3d9wrap.dll, version: 8.17.13.2000, time stamp: 0x51709939
Exception code: 0xc0000005
Fault offset: 0x000089b4
Faulting process id: 0x2930
Faulting application start time: 0x01ce82f949a67d51
Faulting application path: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\Photoshop.exe
Faulting module path: C:\Program Files (x86)\NVIDIA Corporation\CoProcManager\nvd3d9wrap.dll
Report Id: 8c8b9c41-eeec-11e2-8db7-24fd5200e17c
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2013-07-17T14:24:12.000000000Z" />
    <EventRecordID>8903</EventRecordID>
    <Channel>Application</Channel>
    <Computer>TAG004144.tagusa.com</Computer>
    <Security />
  </System>
  <EventData>
    <Data>Photoshop.exe</Data>
    <Data>14.0.0.0</Data>
    <Data>51763d4f</Data>
    <Data>nvd3d9wrap.dll</Data>
    <Data>8.17.13.2000</Data>
    <Data>51709939</Data>
    <Data>c0000005</Data>
    <Data>000089b4</Data>
    <Data>2930</Data>
    <Data>01ce82f949a67d51</Data>
    <Data>C:\Program Files (x86)\Adobe\Adobe Photoshop CC\Photoshop.exe</Data>
    <Data>C:\Program Files (x86)\NVIDIA Corporation\CoProcManager\nvd3d9wrap.dll</Data>
    <Data>8c8b9c41-eeec-11e2-8db7-24fd5200e17c</Data>
  </EventData>
</Event>
    Jul 17, 2013 10:25 AM   in reply to chadpreslar
    Your NVidia video card driver is crashing.  Update your driver from NVidia's website. If that does not help, then contact NVidia so they can get more information to fix the driver bug.
    Aug 28, 2013 9:21 AM   in reply to Chris Cox
    I just renamed the
    C:\Program Files (x86)\NVIDIA Corporation\CoProcManager\nvd3d9wrap.bad
    And photoshop will now launch, for what it's worth.
    Aug 28, 2013 5:00 PM   in reply to ryder_s
    You really need to update the driver to get that DLL fixed, it is part of the driver, and the driver might need it to function.
    Aug 28, 2013 5:17 PM   in reply to Chris Cox
    Well. I'm current on the nvidia driver and the lastest version installed the same file on my machine, I renamed it bad because once again photoshop was not working, and then once it was .bad again, photoshop was fine. I looked into what the driver was and it's for storing screen resolutions and other misc information. It didn't sound that mission critical, and I haven't crashed again today. I'll keep going and let you know if my system blows up, but for something which is supposed to be rock solid driver wise--- a quadro 4000m-- I'm not impressed.
    Also, this issue had broken cs6. CS6 works as well now. I should also note that there is an NVIDIA folder for the 64bit version of the driver as well. I had to rename the file in:
    C:\Program Files\NVIDIA Corporation\coprocmanager\
    I had to do this after completely nuking the driver back to nothing with Driver Sweeper and rebooting and installing the 320.78-quadro-notebook-win8-win7-64bit-international-whql drive. So I'm just giving anyone else that runs into this options, because I was really upset yesterday when photoshop would insta-crash upon launch. And since the file has the same early june date that I originally renamed .bad, I don't have a lot of faith that nVidia is going to fix it.
    Aug 29, 2013 2:16 PM   in reply to ryder_s
    OOH! well I was wrong. I reported the bug at nvidia, and "Ray" got back to me, the new beta drivers fix the issue:
    https://developer.nvidia.com/opengl-driver
