Why is it not possible to separate the dimensions of the top position in a rectangle?
Jul 17, 2013 5:50 PM
See the screen shot below.
Because I'm using a repeater I'd like to separate the dimensions for finer animation control up in this top Position of the Rectangle.
Why is this not possible?
    Jul 17, 2013 3:06 PM   in reply to dissidently
    Not there. Can only do that in the transform property. You should add a feature request.
    Jul 17, 2013 5:02 PM   in reply to dissidently
    Has nobody ever requested this before?
    Oh, they might have, but feature requests are like voting in a Chicago election: do it early and often.
    Jul 17, 2013 5:50 PM   in reply to dissidently
    very few
    Jul 17, 2013 11:10 PM   in reply to dissidently
    You can of course manually isolate all properties by tying them to single-stream expression controls (sliders)...
    Mylenium
    Jul 18, 2013 1:55 PM   in reply to dissidently
    1. Add a slider to your layer by selecting Effect>Expression Controls>Slider Control
    2. Duplicate your slider
    Add this expression to the 2 axis value you want to control:
    x = effect("Slider Control")("Slider");
    y = effect("Slider Control 2")("Slider");
    [x, y]
    To avoid typing everything you can simply use the pickwhip like this:
    I just typed "y =" and then clicked the pickwhip and pointed to the Slider 2 value.
    Hope this helps. Unfortunately, you won't get any Bezzier curves you can animate this way. You could however, animate a null in X and another null in Y and then use the pickwhip to tie the x and y values to the nulls. This would give you Bezzier curves in the Comp window that you could adjust manually.
    Jul 19, 2013 6:37 AM   in reply to dissidently
    You haven't typed the whole expression in.
    In Rick's expression, x and y are just variables and AE doesn't know what to do with these. But AE expects you to return a 2-dimensional array at the end of the expression:
    //    This assumes that you have 2 sliders on the shape layer,
    //     and that they're named "X" and "Y"
    var x = effect("X")(1);
    var y = effect("Y")(1);
    //   Now "return" the array
    [x, y]
    Dec 2, 2013 4:34 PM   in reply to Todd_Kopriva
    Just to add to the votes, I NEED to be able to separate X and Y in ALL of the position properties, not just in the "Transform" sub-menu.
    I'm trying to get realistic character animation, Pixar style, as per my training through Animation Mentor and experience beyond.
    But I can't do exactly what I need with, for instance, the Puppet Pin Tool because I can't separate X and Y.
    Even something simple like the bouncy ball - as per this video - http://tv.adobe.com/watch/learn-after-effects-cs4/animating-precisely- with-separate-dimensions/
    If I make my ball connected to a Puppet Pin, I can't properly animate a bouncy ball. Imagine that difficulty multiplied as I apply the same problem to a full character rig with arms and legs. It seems pointless having the Pin tool at all if I can't properly control it.
    This is a big problem, as I've been using Adobe steadily for six years since CS3, and I've just discovered the graph editor has been removed from Flash, per CC. Where else can I go if not at least to AE?
    If I can't get these controls over my animation, I'd have to either animate frame-by-frame, or move over to another product, which would be a shame because I love Adobe and I know it's possible.
    I know I'm in a minority, but PLEASE consider adding the "Separate Dimensions" functionality to ALL aspects (I'd even wish for it on rotation, scale, etc.) I would find this not only extremely useful but actually necessary to do what I am trying to do.
    ianalexh (Animated Critic).
    Dec 2, 2013 4:39 PM   in reply to alexanderflash
    This needs to be done separately for each property.
    Submit a detailed feature request here listing in priority order the specific properties for which you need this:
    http://adobe.ly/feature_request
    Dec 2, 2013 5:02 PM   in reply to Todd_Kopriva
    Awesome - just did it. Thanks so much!
    - ian
