StigOfNorway
Moving from folder structure to Lightroom (EXIF/IPTC)?
Jul 18, 2013 2:16 AM
Tags: #folder_structure #iptc_tags #folder_names
I have +25k images organized in a folder structure today. This structure has served me well for many years, but I realize that it has it limits.
Testing Lightroom made me decide to go for a new approach, but having some 'nightmares' of how to include my images from my old folder structure (25k images....)
I know I can keep my folders intact in Lightroom, and I have done this. But I also want to have some kind of description on EXIF/IPTC. Today this description is in the folder name, and only there.
How can I automatic include the images current folder name into the image file IPTC Caption or any other EXIF/IPTC field? I want to do this for all images and folders in one batch, and not select each folder manually.
The old images will be more in line with images I import from now on, and they will at least be universal searchable based on the old folder name.
Is there any software that's ready to go for this?
Could it be a task for Automator?
I have access to both PC and MAC for this kind of batch operation.
/Stig of Norway
    Jul 18, 2013 3:39 AM   in reply to StigOfNorway
    You can do this using a slightly modified version of the "Field Loader" preset of the File Renamer plugin (you'll not be renaming any files, it's just a way to do what you want to do...). I can help, if you want to try this approach - consider contacting me outside the forum.
    Jul 18, 2013 4:07 AM   in reply to StigOfNorway
    The question isn't about renaming files, is it? You want to know about automatically copying the image's folder name into IPTC fields? You would need a plugin to do that, and it is pretty easy with my Search and Replace plugin.
    Jul 18, 2013 4:23 AM   in reply to StigOfNorway
    In two stages - transfer the folder to the IPTC field, then search and replace the dates.
    Sep 5, 2013 6:54 PM   in reply to StigOfNorway
    Stig:
    Did you ever have success? I've downloaded Rob Cole's rc File Renamer plugin and would simply like to copy my folder structure to the headline field in EXIF. Would you be kind enough to show me how?
    Gregg
    Sep 8, 2013 2:18 AM   in reply to gschlau
    Hi Gregg,
    First off, I'd like to say that John Beardy's plugin really is much more straight forward for doing this. That said, it can be done using file renamer thusly:
    0. Download and install latest version of file renamer (v1.9 or better).
    1. Select 'Field Loader' preset in plugin manager, preset manager section.
    2. Select 'Edit Advanced Settings' from same (preset selection) drop-down menu.
    3. Change
    _t.formattedMetadataFieldIdForRenaming = 'caption'
    to
    _t.formattedMetadataFieldIdForRenaming = 'headline'
    and change
    _t.formattedMetadataFieldIdForSource = { type='fmt', id='title' }
    to
    _t.formattedMetadataFieldIdForSource = { type='raw', id='path' } -- for full path
    or
    _t.formattedMetadataFieldIdForSource = { type='fmt', id='folderName' } -- for parent folder name only.
    then
    4. invoke 'Rename Files - Start' from the Library Menu -> Plugin Extras.
    And that should do it (you can ignore prompts talking about file renaming, since, well, you'll not be renaming any files...).
    Please contact me outside the forum for additional plugin support - thanks.
    Rob
    Sep 9, 2013 6:31 AM   in reply to StigOfNorway
    Thanks Stig and Rob for your excellent directions. Appreciate it!
