We have CF10 installed with two instances, cfusion and dev. There are lots of instructions on how to change the doc root by modifying the server.xml file, which i did successfully on the cfusion instance. The server.xml file on the second instance, dev, looks entirely different from the first primary instance and has no context to set a different doc root and/or aliases.
Any clue how to change the doc root on a second instance?
Mike Oatsvall
P.S. there is a docroot global variable in the startup script for the dev instance. Which was not set. I tried setting that and restarted, no joy.
Well, Even though there is no predefined context at the bottom of server.xml I just copied the same directives from the primary instance and modified the pathing and it works!
Now we know....
