Acrobat keeps crashing
Jul 18, 2013 1:57 PM
The company that I work for has been having an issue with three machines (1 Dell OptiPlex 780 and 2 Dell OptiPlex 760's) where Adobe Acrobat XI Standard will crash and then report that adobe.exe has failed. This force closes the program causing you to rescan everything that you had initially put through the scanner (This happens intermittently). When running Debug Diagnostic tool I received a few different errors. We are running this across multiple platforms, the 780 is running Windows 7, and the two 760’s are currently running Windows XP and have the same issue on all three machines. Unfortunately I can only assume they are the same errors because they show the same symptoms.
In Acrobat__PID__1380__Date__04_08_2013__Time_09_47_44AM__995__Second_Ch ance_Exception_C0000374.dmp the assembly instruction at ntdll!RtlReportCriticalFailure+57 in C:\Windows\System32\ntdll.dll from Microsoft Corporation has caused an unknown exception (0xc0000374) on thread 0
Thread 0 - System ID 5576
Entry point
  0x00000000
Create time
  4/8/2013 9:47:19 AM
Time spent in user mode
  0 Days 00:00:06.505
Time spent in kernel mode
  0 Days 00:00:00.982
This thread is not fully resolved and may or may not be a problem. Further analysis of these threads may be required.
Function
  Source
ntdll!RtlpReportHeapFailure+21
ntdll!RtlpLogHeapFailure+a1
ntdll!RtlFreeHeap+64
kernel32!HeapFree+14
msvcr100!free+1c
Acrobat_54560000!CTJPEGDecoderRelease+134a7
Acrobat_54560000!AX_ASRamFileSysSetLimitKB+1a4021
Acrobat_54560000!AX_ASRamFileSysSetLimitKB+1a4e9a
Acrobat_54560000!AX_ASRamFileSysSetLimitKB+1a5bf7
Scan!PlugInMain+19806
Scan!DllUnregisterServer+1c186
Scan!DllUnregisterServer+1c554
Scan!DllUnregisterServer+f568
Scan!DllUnregisterServer+16af
Scan!DllUnregisterServer+1d65
Scan!DllUnregisterServer+6c05
Scan!DllUnregisterServer+1ebf6
Scan!DllUnregisterServer+1b845
Scan!DllUnregisterServer+1bcb6
Scan!PlugInMain+20b87
Scan!PlugInMain+21cb8
Scan!PlugInMain+229df
Scan!PlugInMain+22b0c
Scan!PlugInMain+22c06
Acrobat_54560000!CTJPEGRotateOptions::operator=+31b2a9
Acrobat_54560000!CTJPEGRotateOptions::operator=+a616e
Acrobat_54560000!CTJPEGRotateOptions::operator=+a67b4
Acrobat_54560000!CTJPEGRotateOptions::operator=+a7185
Acrobat_54560000!CTJPEGRotateOptions::operator=+34287f
Acrobat_54560000!DllUnregisterServer+2c0f4
Acrobat_54560000!DllUnregisterServer+2c16b
Acrobat_54560000!CTJPEGRotateOptions::operator=+a62c1
Acrobat_54560000!CTJPEGRotateOptions::operator=+a633b
Acrobat_54560000!CTJPEGRotateOptions::operator=+33f54b
Acrobat_54560000!CTJPEGRotateOptions::operator=+c9724
Acrobat_54560000!CTJPEGRotateOptions::operator=+ca0ed
Acrobat_54560000!CTJPEGRotateOptions::operator=+d4b5f
Acrobat_54560000!DllCanUnloadNow+6262
Acrobat_54560000!DllCanUnloadNow+5e7e
user32!InternalCallWinProc+23
user32!UserCallWinProcCheckWow+14b
user32!DispatchMessageWorker+35e
user32!DispatchMessageW+f
Acrobat_54560000!DllCanUnloadNow+20270
Acrobat_54560000!DllCanUnloadNow+200e5
Acrobat_54560000!AcroWinMain+425
Acrobat_54560000!AcroWinMain+16
Acrobat+1957
Acrobat+41d4
Acrobat!std::_Init_locks::operator=+28d
kernel32!BaseThreadInitThunk+e
ntdll!__RtlUserThreadStart+70
ntdll!_RtlUserThreadStart+1b
In Acrobat__PID__4384__Date__05_13_2013__Time_03_13_19PM__529__Second_Ch ance_Exception_C0000005.dmp the assembly instruction at Acrobat_5f6a0000!CTJPEGDecoderRelease+13469 in C:\Program Files\Adobe\Acrobat 11.0\Acrobat\Acrobat.dll from Adobe Systems Incorporated has caused an access violation exception (0xC0000005) when trying to write to memory location 0x6d614e6e on thread 0
Thread 0 - System ID 4136
Entry point
  0x00000000
Create time
  5/13/2013 3:13:01 PM
  0 Days 00:00:06.458
  0 Days 00:00:00.577
Function
  Source
Acrobat_5f6a0000!AX_ASRamFileSysSetLimitKB+1a4021
Acrobat_5f6a0000!AX_ASRamFileSysSetLimitKB+1a4e9a
Acrobat_5f6a0000!AX_ASRamFileSysSetLimitKB+1a5bf7
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+238a7b
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+31b2a9
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+a616e
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+a67b4
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+a7185
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+34287f
Acrobat_5f6a0000!DllUnregisterServer+2c0f4
Acrobat_5f6a0000!DllUnregisterServer+2c16b
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+a62c1
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+a633b
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+33f54b
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+c9724
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+ca0ed
Acrobat_5f6a0000!CTJPEGRotateOptions::operator=+d4b5f
Acrobat_5f6a0000!DllCanUnloadNow+6262
Acrobat_5f6a0000!DllCanUnloadNow+5e7e
Acrobat_5f6a0000!DllCanUnloadNow+20270
Acrobat_5f6a0000!DllCanUnloadNow+200e5
Acrobat_5f6a0000!AcroWinMain+425
Acrobat_5f6a0000!AcroWinMain+16
Acrobat+1957
Acrobat+41d4
In Acrobat__PID__4928__Date__04_12_2013__Time_02_22_41PM__80__Second_Cha nce_Exception_C0000005.dmp the assembly instruction at BIB!BIBInitialize4+3316 in C:\Program Files\Adobe\Acrobat 11.0\Acrobat\BIB.dll from Adobe Systems Incorporated has caused an access violation exception (0xC0000005) when trying to read from memory location 0x0000001d on thread 0
Thread 0 - System ID 3136
Entry point
  0x00000000
Create time
  4/12/2013 2:22:08 PM
  0 Days 00:00:17.986
  0 Days 00:00:01.388
Function
  Source
BIB!BIBInitialize4+3fc0
Acrobat_52370000!AcroWinBrowserMain+1362d
Acrobat_52370000!DllCanUnloadNow+ef30b
Acrobat_52370000!DllCanUnloadNow+ef05e
Acrobat_52370000!DllCanUnloadNow+eef48
Acrobat_52370000!DllCanUnloadNow+ce879
Acrobat_52370000!DllCanUnloadNow+cd10b
Acrobat_52370000!DllCanUnloadNow+cb3f0
Acrobat_52370000!DllCanUnloadNow+cb1dc
Acrobat_52370000!DllCanUnloadNow+c9aea
Acrobat_52370000!DllCanUnloadNow+c97aa
Acrobat_52370000!DllCanUnloadNow+c96ba
Acrobat_52370000!DllCanUnloadNow+c9534
Acrobat_52370000!DllCanUnloadNow+5f38
Acrobat_52370000!DllCanUnloadNow+5e7e
user32!DispatchClientMessage+da
user32!__fnDWORD+24
ntdll!KiUserCallbackDispatcher+2e
user32!NtUserDispatchMessage+c
user32!DispatchMessageWorker+3d5
user32!DispatchMessageA+f
Scan!DllUnregisterServer+17e6e
PaperCapture+183d1
PaperCapture+f2d7
PaperCapture+fb68
Scan!PlugInMain+18147
Scan!DllUnregisterServer+1b608
Acrobat_52370000!CTJPEGRotateOptions::operator=+238a7b
Acrobat_52370000!CTJPEGRotateOptions::operator=+31b2a9
Acrobat_52370000!CTJPEGRotateOptions::operator=+a616e
Acrobat_52370000!CTJPEGRotateOptions::operator=+a67b4
Acrobat_52370000!CTJPEGRotateOptions::operator=+a7185
Acrobat_52370000!CTJPEGRotateOptions::operator=+34287f
Acrobat_52370000!DllUnregisterServer+2c0f4
Acrobat_52370000!DllUnregisterServer+2c16b
Acrobat_52370000!CTJPEGRotateOptions::operator=+a62c1
Acrobat_52370000!CTJPEGRotateOptions::operator=+a633b
Acrobat_52370000!CTJPEGRotateOptions::operator=+33f54b
Acrobat_52370000!CTJPEGRotateOptions::operator=+c9724
Acrobat_52370000!CTJPEGRotateOptions::operator=+ca0ed
Acrobat_52370000!CTJPEGRotateOptions::operator=+d4b5f
Acrobat_52370000!DllCanUnloadNow+6262
Acrobat_52370000!DllCanUnloadNow+20270
Acrobat_52370000!DllCanUnloadNow+200e5
Acrobat_52370000!AcroWinMain+425
Acrobat_52370000!AcroWinMain+16
Acrobat+1957
Acrobat+41d4
In Acrobat__PID__5856__Date__04_12_2013__Time_03_57_00PM__279__Second_Ch ance_Exception_C0000005.dmp the assembly instruction at ntdll!$$VProc_ImageExportDirectory+9f46 in C:\Windows\System32\ntdll.dll from Microsoft Corporation has caused an access violation exception (0xC0000005) when trying to read from memory location 0x005f25bd on thread 0
Thread 0 - System ID 5628
Entry point
  0x00000000
Create time
  4/12/2013 3:51:30 PM
  0 Days 00:01:32.617
  0 Days 00:00:07.441
Function
  Source
kernel32!GetLongPathNameW+61
Acrobat_52370000!DllCanUnloadNow+e7f86
Acrobat_52370000!DllCanUnloadNow+2cdcb
Acrobat_52370000!DllCanUnloadNow+2cd5e
Acrobat_52370000!DllCanUnloadNow+2cd12
Acrobat_52370000!DllCanUnloadNow+2cc90
Acrobat_52370000!DllCanUnloadNow+2caba
Acrobat_52370000!AX_ASRamFileSysSetLimitKB+16d071
PaperCapture+c3ce
PaperCapture+fbac
Scan!PlugInMain+1821c
Scan!DllUnregisterServer+1b93e
Scan!PlugInMain+22f8f
Scan!PlugInMain+22fde
Acrobat+1957
Acrobat+41d4
What I Have Tried:
-Giving permissions to certain files (I believe this was Bib.dll and ntdll.dll but I am unsure it has been a while).
-Made exceptions in our anti-virus for AdobeArm.exe and AGM.dll.
-I have tried multiple uninstall and reinstall as well as repair operations.
-Booted the program as Administrator (even though my account is an Admin) as well as removed all of the add-ons and tried booting Acrobat up.
-Run memory diagnostics on the 780 and one of the 760’s and all machines passed.
-Started Acrobat with Anti-virus disabled.
I believe I have covered everything that was attempted but there could be more. I found most of these remedies on forums such as this one. From what I understand this error is generated when a part of the memory is being used by another program and when it was supposed to release a section of the memory it did not do so. Although I may be misunderstanding what I read.
Hope this information that I gave you is enough and thanks ahead of time for any help that you can provide.
