Errors Sending Audio to Audition
Jul 19, 2013 8:44 AM
The Issue
Selecting "Edit > Edit in Adobe Audition" from within B Video composition (which contains a video file) while in B Frame composition (which contains B Video composition) results in the following errors:
After Effects can't continue: damaged i/o structure.
( 39 :: 113 )
[OK]
Clicking ok then says
Before quitting, you have one chance to save your project (don't use the same
name as the original).
[OK]
Which is quite terrifying
Choosing to save or hitting cancel results in the application closing.
What I was trying to do
I'm just trying to send some audio to Audition for editing. I did it once and it brought over my in and out points based on how I cropped it, which was perfect. Doing it a second time on another video however, did not bring over the in and out points but the audio for the entire video file. What am I missing?
    Jul 19, 2013 1:46 AM   in reply to Xoxidine
    Send to only works with source files, not compositions. You need to send the original video and/ or spliced out separate audio track.
    Mylenium
    Jul 19, 2013 2:43 AM   in reply to Xoxidine
    It works as it should - you send the source file which doesn't know anything about your trims. AE works with references, it doesn't physically modify your sources in any way. if you want that, you will have to render the audion properly to a separate file.
    Mylenium
    Jul 19, 2013 10:00 AM   in reply to Xoxidine
    You simply select the different video track and send that asset too Audition.
    Jul 19, 2013 3:51 PM   in reply to Xoxidine
    The in point is not set for the layer you showed in your example. That would do it. Put the CTI at 0 frames and press Ctrl/Cmnd + [ to set an in point and try again.
