bro577569
NetStream : send text data
Jul 19, 2013 2:24 PM
hi,
I try to do a really simple chat with NetStream. I would like to send a text on my netstream (I don't want to use camera, only text !)
I run a red5 server and I use flex 4.5
As I my new, I don't understand what is the best way to do this. I try code to send video streaming and it works but I can't send text.
Is somebody have a really simple example to do this ?
    Jul 21, 2013 8:25 AM   in reply to bro577569
    //Simple solution,
    import flash.events.*
    public var chat_so:SharedObject;
    public var nc:NetConnection;
    public var username:String;
    public function createConnection():void
        nc = new NetConnection();
        nc.objectEncoding = ObjectEncoding.AMF0;
        nc.addEventListener( NetStatusEvent.NET_STATUS, netStatusHandler );
        nc.connect( "rtmp://path_to_red5/oflaDemo",username);
    //Then in the netStatusHandler you would need something like this....
    public function netStatusHandler( event:NetStatusEvent ):void
        switch( event.info.code )
            case "NetConnection.Connect.Success":
                 connectComponents()
            break;
            case "NetConnection.Connect.Rejected":
            break;
    //This sets up a SyncEvent handler...
    public function connectComponents():void
        SharedObject.defaultObjectEncoding  = flash.net.ObjectEncoding.AMF0;
        chat_so = SharedObject.getRemote("chat_so", nc.uri, false);
        chat_so.addEventListener( SyncEvent.SYNC, usersSyncHandler_chat );
        chat_so.connect( nc );
    //This fires when the sharedObject is updated...
    public function usersSyncHandler_chat( event:SyncEvent ):void
            var results:Object = event.target.data;
            for( var a:String in results )
            if (  results[ a ] != undefined )
                 //this will add a message to a text component...
                chatCanvas.htmlText += "" + results[ a ];
                chatCanvas.validateNow();
                chatCanvas.verticalScrollPosition = chatCanvas.maxVerticalScrollPosition;
    //this button or key listener function will send a message by updating a sharedObject on all clients...
    public function sendMessage():void
          //grab message from an input text component.
          var msg:String = chatInputTxt.text;
          //send the msg...
          chat_so.setProperty("textValue", username + ": " + msg );
          //clear text from chatInputTxt.text
          chatInputTxt.text = "";
    HTH
