Hi all, I'm quite new to FMS, I hope someone can help me solve this problem, thank you.
I run a FMS 4.5 for a recording service. But some of our member cannot record. The recorded flv file was only 222 bytes. below is the different between successful case and failed case of recording.
Success case: onstatus event of netstream after it publish, the server returned:
clientid: qAArABAA description: 1942829/1374303941188 is now published. code: NetStream.Publish.Start level: status
clientid: qAArABAA description: Recording 1942829/1374303941188. code: NetStream.Record.Start level: status
Failed case: onstatus event of netstream after it publish, the server returned only 1 message:
clientid: qAAsABAA description: 1800194/1374303943063 is now published. code: NetStream.Publish.Start level: status
Once more thing is that only visitor from Google Chrome got this problem, cause the header of request of failed recording case always look like: "HTTP_USER_AGENT":"Mozilla\/5.0 (Windows NT 6.1) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/28.0.1500.72 Safari\/537.36"
application log:
2013-07-20 | 05:53:14 | 1692 | (i)2611173 | Application level recording configuration: General[flags: 0, keyframe interval: 0, max size: -1, max length: -1, io buffer size: -1], Fragment[frag duration: 4000, seg duration: 0, duration precision: 100, allowed drift: 1000, frame rate: 0.000000, frames per interval: 0, intervals per frag: 1, frame precision: 1, disk management duration: 0.000000], ContentProtection[enabled=false(overridable)] | - |
2013-07-20 | 05:53:17 | 1692 | (i)2611173 | Event level recording configuration: General[flags: 1, keyframe interval: 60000, max size: -1, max length: -1, io buffer size: -1], Fragment[frag duration: 4000, seg duration: 0, duration precision: 100, allowed drift: 1000, frame rate: 0.000000, frames per interval: 0, intervals per frag: 1, frame precision: 1, disk management duration: 0.000000], ContentProtection[enabled=false(overridable)] | - |
2013-07-20 | 05:59:46 | 1692 | (i)2611173 | Event level recording configuration: General[flags: 1, keyframe interval: 60000, max size: -1, max length: -1, io buffer size: -1], Fragment[frag duration: 4000, seg duration: 0, duration precision: 100, allowed drift: 1000, frame rate: 0.000000, frames per interval: 0, intervals per frag: 1, frame precision: 1, disk management duration: 0.000000], ContentProtection[enabled=false(overridable)] | - |
2013-07-20 | 06:01:25 | 1692 | (i)2611173 | Event level recording configuration: General[flags: 1, keyframe interval: 60000, max size: -1, max length: -1, io buffer size: -1], Fragment[frag duration: 4000, seg duration: 0, duration precision: 100, allowed drift: 1000, frame rate: 0.000000, frames per interval: 0, intervals per frag: 1, frame precision: 1, disk management duration: 0.000000], ContentProtection[enabled=false(overridable)] | - |
2013-07-20 | 06:02:52 | 1692 | (i)2611173 | Event level recording configuration: General[flags: 1, keyframe interval: 60000, max size: -1, max length: -1, io buffer size: -1], Fragment[frag duration: 4000, seg duration: 0, duration precision: 100, allowed drift: 1000, frame rate: 0.000000, frames per interval: 0, intervals per frag: 1, frame precision: 1, disk management duration: 0.000000], ContentProtection[enabled=false(overridable)] | - |
2013-07-20 | 06:28:15 | 1692 | (i)2651170 | Unloaded application instance newApp/soundrecord | - |
core log:
2013-07-20 | 02:04:41 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374260668844 | - |
2013-07-20 | 02:05:22 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374260711047 | - |
2013-07-20 | 02:09:10 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374260939203 | - |
2013-07-20 | 02:10:16 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374261004938 | - |
2013-07-20 | 02:13:44 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374261213218 | - |
2013-07-20 | 02:22:16 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374261724250 | - |
2013-07-20 | 02:23:47 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374261815766 | - |
2013-07-20 | 02:26:24 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374261972531 | - |
2013-07-20 | 02:27:19 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374262028407 | - |
2013-07-20 | 02:28:31 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374262099779 | - |
2013-07-20 | 02:29:30 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374262159469 | - |
2013-07-20 | 02:30:05 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374262194218 | - |
2013-07-20 | 02:30:36 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374262224703 | - |
2013-07-20 | 02:41:00 | 4284 | (i)2611173 | Metadata not available before the flush of first segment. Default metadata recorded for stream D:\FMS3\applications\newApp\streams\soundrecord\1951187\1374262849404 | - |
2013-07-20 | 03:04:33 | 4284 | (i)2581247 | Core (4284) disconnected from edge. | - |
2013-07-20 | 03:04:33 | 4284 | (i)2581233 | Core (4284) disconnecting from admin: 200. | - |
base on messeges return from FMS, after NetStream publish then -> Publishing has started. -> error, something wrong (recording should start, but it hasn't started) <------------- any idea?
I has already known why that is. Because of the new chrome version update micro phone security, The browser disabled micro phone function. So my swf didn't use it. The problem fixed. Thanks everyone.
