jware-cpg.org
I cannot change setting of PostParametersLimit
Jul 20, 2013 11:20 AM
Tags: #coldfusion9 #cf9
I have tried using the documented approach of adding the parameter to Neo-runtime.xml (the param was not in the file at all, I added it) and by createObject("component","cfide.adminapi.runtime").setRuntimeProperty ("postParametersLimit", 120) (we successfully use this to set PostSizeLimit)
I have this problem in CF9.0.0 and CF 9.0.2
    Jul 20, 2013 4:02 PM   in reply to jware-cpg.org
    The documented approach is to set the maximum number of post request parameters or the maximum size of post data on the page Server Settings >> Settings in the ColdFusion Administrator.
    Jul 22, 2013 6:01 AM   in reply to jware-cpg.org
    I am on version 10, so I can only see your point now. In any case, I would suggest you check yourself whether PostParametersLimit is in the list of variables which can be set as above.
    To do so, open http://yourdomain/CFIDE/adminapi/runtime.cfc. Then look at the list under setRuntimeProperty.
