Liquify options
Jul 20, 2013 5:16 PM
I haven't seen this question exactly but when I Click Filter > Liquify, no options appear.  What am I doing wrong?
    Jul 20, 2013 6:08 PM   in reply to MJG
    Maybe you could clarify when you say no options appear, you mean the liquify dialog doesn't appear or some of the options
    in the liquify dialog seem to be missing?
    What version of photoshop and operating system are you using?
    If your using photoshop cs6/cc, clicking Advanced Mode in the liquify dialog will give you the standard dialog as your used to seeing in earlier versions of photoshop.
    Jul 20, 2013 6:34 PM   in reply to MJG
    So you don't see the liquify dialog as the above screenshot?
    Do other filters work such as the Filter Gallery or Oil Paint?
    Jul 20, 2013 6:39 PM   in reply to MJG
    Like this:
    Jul 20, 2013 7:26 PM   in reply to MJG
    That doesn't sound right as photoshop cs6 should only have one Liquify filter under the filter menu at the top.
    Was the other Liquify filter under Filter>Distort>Liquify?
    Have you pointed the Additional Plug-Ins folder under Photoshop (Edit)Preferences>Plug-Ins in photoshop cs6 to an earlier version
    of photoshop or photoshop elements plug-ins folder or copied any plug-ins from an earlier version of photoshop or photoshop elements to the photoshop cs6 Plug-Ins folder?
    Jul 20, 2013 8:48 PM   in reply to MJG
    Your filter menu in photoshop cs6 should look something like below, plus any third party plugins you may have installed, which are usually at the
    very bottom of the filter menu.
    Liquify should have a default shortcut of Shift+Ctrl+X (Shift+Cmd+X)
    Could you post a screenshot of how your filter menu looks in photoshop cs6?
    Maybe also the contents of the Help>Info from within photoshop cs6.
    Jul 22, 2013 11:20 AM   in reply to MJG
    The last filter item reapplies the settings of the last filter. It won't show the UI because you already specified the settings.
    That's normal - and you're just mistaking the last filter option for the Liquify filter normal position.
    Jul 22, 2013 5:00 PM   in reply to MJG
