kornbif
Is there a Pantone equivalent to RGB black  0,0,0?
Jul 20, 2013 8:38 PM
    Jul 20, 2013 9:34 PM   in reply to kornbif
    Hi Kornbif,
    You could check for 419 and 426 pantone color.
    Is there any specific reason you are looking for Pantone equivalent for the RGB value ?
    What is the intent of the Indesign document ?
    Jul 20, 2013 10:13 PM   in reply to kornbif
    It isn't as simple as you make it. Your question about RGB=(0,0,0) leaves out a fairly critical piece of information. Exactly what RGB color space are you intested in? Adobe RGB? sRGB? Other? Based on what you wrote, your project also deals with CMYK color as well. But you have the same issue there. There are many different CMYK color spaces. You must specify which when trying to equate colors.
              - Dov
    Jul 21, 2013 2:37 AM   in reply to kornbif
    "Equivalent" is a pretty loose term, too. Pantone has spot to process "conversion" numbers for many of their colors, but I"m not sure I would consider most of them as truly equivalent.
  • Rob Day
    Oct 16, 2007
    Jul 21, 2013 11:23 AM   in reply to kornbif
    Hmmm I see, I might just have to ask the professor about it
    You would hope the point of the assignment is to show  there are no equivalents because color conversions depend on the device, that's why there's such a complex color management system in place.
    Single hit process black printed at normal densities can't come close to 0|0|0 in any of the provided RGB spaces, and you would have the same problem with single hits of any of the Pantone blacks. Pantone Black 6 C is the blackest at Lab 8|-2|-7.
    Or if your starting color is 128|128|128 AdobeRGB gray and you want the CMYK values for a sheetfed coated press in Japan, sheetfed coated in the US, and a US Newspaper, you get this range of conversions:
