slosek
when import slide show from photoshop to premier top half is black & half of picture on bottom
Jul 21, 2013 6:24 AM
when i import from photoshop to premier, the top half is black & the other is the bottom part of the picture.
    Jul 21, 2013 6:37 AM   in reply to slosek
    If the slideshow is wmv read the announcement at the top of the forum.
    http://helpx.adobe.com/premiere-pro/kb/wmv-files-corrupted-import-or.h tml
    Jul 21, 2013 7:00 AM   in reply to Ann Bens
    Also note that, if you're porting your slideshow from the Organizer's Slideshow creator to Premiere Elements, the WMV is not the best format for doing so.
    Ideally you should choose the slideshow output option to Edit in Premiere Elements.
    This sends the slideshow to Premiere Elements in an interchange format that, if you'd like, can be broken apart in Premiere Elements (by right-clicking on it on the timeline and selecting Break Apart Slideshow) and edited further.
    Jul 21, 2013 12:45 PM   in reply to slosek
    stosek
    Your original thread question should have been taken care of according the Announcement at the top of this forum...that involves the removal of the Windows Update kb causing the      1/2 wmv display. Have you been there and done that? If that is out of the way, then...
    Lots of details on your project to sort out, but I will ask the question "Have you put a stop marker at the end of the last item on the Premiere Elements Timeline?" If so, remove it. It is not needed and is one of the major causes for type of problem that you described in your latest post. Have you expanded your Timeline looking for left over slivers? Typically they present as very thin vertical black lines scattered about the track content.
    What are the pixel dimensions of the photos that went into the slideshow, now that you are trying the Photoshop Elements Slideshow Editor Output option of Edit With Premiere Elements Editor?
    What is your end product...NTSC or PAL DVD-VIDEO standard or widescreen on DVD disc? In the burn dialog for burn to DVD, what does the Quality Area show for Space Required and Bitrate? And, another classical question...if you burn to folder instead of disc for your DVD-VIDEO, does the burn to folder go to success whereas the burn to disc does not?
    Let us start here and then decide further troubleshooting.
    Thanks.
    ATR
    Jul 21, 2013 2:55 PM   in reply to slosek
    slosek
    Once you hit Burn in the burn dialog, you can see a progress bar in that area which typically shows the sequence
    Encoding Menu
    Encoding Media
    Compiling Media
    Burn
    When are you getting the transcoding area? Does it show a % done at the time of the error?
    Also, if you expand the Timeline do you see any gaps...maybe files that are not right up against one another? Or are you seeing a lot of tiny vertical black lines scattered among the Timeline content? And transitions that gave you problems when you tried to place them between your videos or photos?
    And did you ever try the burn to folder to determine if this error pops up and at the same place?
    Just some thoughts for now. If you have not already, please delete that Windows Update kb to get ride of the issues with any .wmv files on that Premiere Elements Timeline.
    ATR
    Jul 25, 2013 6:35 AM   in reply to slosek
    stosek
    It is likely that the offending Windows Update kb has returned.
    For now, set your Windows Updates so that you require notification and your approval for any downloading and installing of any Windows Updates.
    Search again for the Windows Update that you previously deleted as per the Announcement at the top of this forum. And delete it again.
    After that, if you see the offending kb in the Windows Updates Important Updates, right click it and select Hide. It is supposed not to be a bother after that.
    Please let us know the outcome.
    Thanks.
    ATR
