VerifyError: Error #1014: Class spark.components::HGroup could not be found.
Jul 21, 2013 7:32 AM
Tags: #not #class #be #could #found. #spark.components::hgroup
Hi all
I created a  simple flex application which contains following line of codes
<s:HGroup xmlns:fx="http://ns.adobe.com/mxml/2009"
                                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
</s:HGroup>
When I run this application in flex I got the following error on the browser
also there is a warning on the my flash builder console which follows
DescriptionResourcePathLocationType
This compilation unit did not have a factoryClass specified in Frame metadata to load the configured runtime shared libraries. To compile without runtime shared libraries either set the -static-link-runtime-shared-libraries option to true or remove the -runtime-shared-libraries option.IRegion.mxml/IRegion/src/com/regionUnknownFlex Problem
after that i setted -static-link-runtime-shared-libraries=true option in additional compiler arguments after that the warning become error which follows
Unable to locate specified base class 'spark.components.HGroup' for component class 'com.region.IRegion'.IRegion.mxml/IRegion/src/com/regionUnknownFlex Problem
my flex sdk version is flex 4.6.0
Also I have the same problem in the case of s:Button
what I need to do?
Regards
Anish Antony
