Error updating patch: CS6, Log information below
Jul 22, 2013 8:16 AM
Tags: #help #error #fireworks #fireworks_cs6 #patch_failure
Running Windows 7 Enterprise x64 (Should I bother updating since it is a small update only?)
07/22/13 08:14:13:463 | [INFO] |  | OOBE | DE |  |  |  | 8064 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=*
07/22/13 08:14:13:463 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Visit http://www.adobe.com/go/loganalyzer/ for more information
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=*
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | START - Installer Session
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | RIBS version: 7.0.0.108
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Win OS version: 6.1.1.0 64 bit Type: 1
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ::START TIMER:: [Total Timer]
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | CHECK: Single instance running
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | CHECK : Credentials
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Load Deployment File
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | deploymentFile option not given
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | CHECK : Another Native OS installer already running
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Create Required Folders
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Assuming install mode
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Looking up install source path
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Sync Media DB ...
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ::START TIMER:: [Sync Media DB]
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Pre check media db sync
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | End of Pre check media db sync. Exit code: 0
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | :: END TIMER :: [Sync Media DB] took 710.038 milliseconds (0.710038 seconds)
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Ready to initialize session to start with ...
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ::START TIMER:: [CreatePayloadSession]
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Updated source path: C:\Users\nate\AppData\Local\Temp\Adobe\AAMUpdater\AdobeExtensionManag erCS6-6.0\6.0.7\setup
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Updating media info for: {48BC197D-7053-434D-AF69-9233170D1614}
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Ignoring original data since install source is local
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 |   Type: 0, Volume Order: 1, Media Name:
  Path: C:\Users\nate\AppData\Local\Temp\Adobe\AAMUpdater\AdobeExtensionManag erCS6-6.0\6.0.7\setup\payloads\AdobeExtensionManager6.0All-14071322103 4\Install.db
07/22/13 08:14:13:464 | [INFO] |  | OOBE | DE |  |  |  | 8064 | --------------------  END  - Updating Media Sources -  END  --------------------
07/22/13 08:14:13:479 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Supported RIBS version range: [0.0.0.0,7.0.0.108]
07/22/13 08:14:13:479 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ----------------- CreatePayloadSession: machine is x64 ---------------
07/22/13 08:14:16:691 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ______ Verify Dependency Subscribers ______
07/22/13 08:14:16:691 | [INFO] |  | OOBE | DE |  |  |  | 8064 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
07/22/13 08:14:16:691 | [INFO] |  | OOBE | DE |  |  |  | 8064 |   Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}: 0 (0,0)
07/22/13 08:14:16:691 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
07/22/13 08:14:16:693 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Patch Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614} can be applied to product Adobe Extension Manager CS6 6.0.0.0 {83463106-DD1C-4FE5-A61C-DF6715472AD4}
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Setting property "installSourcePath" to: C:\Users\nate\AppData\Local\Temp\Adobe\AAMUpdater\AdobeExtensionManag erCS6-6.0\6.0.7\setup
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Setting property "mode" to: silent
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Setting property "updateManifestPath" to: C:\Users\nate\AppData\Local\Adobe\AAMUpdater\1.0\Data\AdobeExtensionM anagerCS6-6.0\6.0.7\6.0.7.xml
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Setting property "workflow" to: updater
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Overwrite property "extensionsOnly" to: 1
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Overwrite property "mode" to: silent
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Overwrite property "patchesOnly" to: 1
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Overwrite property "updateManifestPath" to: C:\Users\nate\AppData\Local\Adobe\AAMUpdater\1.0\Data\AdobeExtensionM anagerCS6-6.0\6.0.7\6.0.7.xml
07/22/13 08:14:16:738 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Overwrite property "workflow" to: updater
07/22/13 08:14:16:739 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Found payload actions:
07/22/13 08:14:16:739 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Deciding what installer mode to use...
07/22/13 08:14:16:778 | [INFO] |  | OOBE | DE |  |  |  | 8064 | BEGIN Setting requested payload actions
07/22/13 08:14:16:780 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Value returned on lookup of payload: Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614} is: false
07/22/13 08:14:16:780 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Action string for Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}  is install
07/22/13 08:14:16:791 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END Setting requested payload actions
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Collected advanced path check information for INSTALLDIR
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | INSTALLDIR is a well-formed path
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | INSTALLDIR is not the root path
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | INSTALLDIR is on a local volume
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | INSTALLDIR is on a writable volume
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | INSTALLDIR is not on a case sensitive volume
07/22/13 08:14:17:088 | [INFO] |  | OOBE | DE |  |  |  | 8064 | INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
07/22/13 08:14:18:543 | [INFO] |  | OOBE | DE |  |  |  | 8064 | BEGIN InstallOperationsQueue Unordered operations
07/22/13 08:14:18:543 | [INFO] |  | OOBE | DE |  |  |  | 8064 |   Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}:  with operation install
07/22/13 08:14:18:543 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END InstallOperationsQueue Unordered operations
07/22/13 08:14:18:543 | [INFO] |  | OOBE | DE |  |  |  | 8064 | BEGIN InstallOperationsQueue Ordered operations
07/22/13 08:14:18:543 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END InstallOperationsQueue Ordered operations
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Payloads passed preflight validation.
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Call PreSession Custom Hook
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 | BEGIN InstallOperationsQueue Unordered operations
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 |   Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}:  with operation install
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END InstallOperationsQueue Unordered operations
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 | BEGIN InstallOperationsQueue Ordered operations
07/22/13 08:14:18:767 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END InstallOperationsQueue Ordered operations
07/22/13 08:14:18:774 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Calling the custom action code for pre-install for payload Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}
07/22/13 08:14:18:774 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ::START TIMER:: [Payload Operation :{48BC197D-7053-434D-AF69-9233170D1614}]
07/22/13 08:14:18:802 | [INFO] |  | OOBE | DE |  |  |  | 8132 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=*
07/22/13 08:14:18:802 | [INFO] |  | OOBE | DE |  |  |  | 8132 | Installer Operation: PayloadInstaller
07/22/13 08:14:18:802 | [INFO] |  | OOBE | DE |  |  |  | 8132 | Request to install payload
07/22/13 08:14:18:836 | [INFO] |  | OOBE | DE |  |  |  | 8132 | Payload Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
07/22/13 08:14:19:551 | [INFO] |  | OOBE | DE |  |  |  | 8132 | Extracting assets complete. Number assets: 1
07/22/13 08:14:19:551 | [INFO] |  | OOBE | DE |  |  |  | 8132 | CustomizedPatch property not found in database
07/22/13 08:14:19:551 | [INFO] |  | OOBE | DE |  |  |  | 8132 | Beginning installation for payload at C:\Users\nate\AppData\Local\Temp\Adobe\AAMUpdater\AdobeExtensionManag erCS6-6.0\6.0.7\setup\payloads\AdobeExtensionManager6.0All-14071322103 4\Install.db
07/22/13 08:14:19:559 | [ERROR] |  | OOBE | DE |  |  |  | 8132 | DF022: File corruption detected. Re-install the product & then apply the patch again. (Pre checksum mismatch for file "C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6\ZStringResources\uk_UA.xml")(Seq 3)
07/22/13 08:14:19:559 | [WARN] |  | OOBE | DE |  |  |  | 8132 | DW063: Command ARKPatchCommand failed.(Seq 3)
07/22/13 08:14:19:560 | [INFO] |  | OOBE | DE |  |  |  | 8132 | Completing installation for payload at C:\Users\nate\AppData\Local\Temp\Adobe\AAMUpdater\AdobeExtensionManag erCS6-6.0\6.0.7\setup\payloads\AdobeExtensionManager6.0All-14071322103 4\Install.db
07/22/13 08:14:19:600 | [INFO] |  | OOBE | DE |  |  |  | 8064 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
07/22/13 08:14:19:600 | [INFO] |  | OOBE | DE |  |  |  | 8064 | :: END TIMER :: [Payload Operation :{48BC197D-7053-434D-AF69-9233170D1614}] took 827.58 milliseconds (0.82758 seconds) DTR = 565.504 KBPS (0.55225 MBPS)
07/22/13 08:14:19:603 | [INFO] |  | OOBE | DE |  |  |  | 8064 | User specified overrideFile:
07/22/13 08:14:19:608 | [INFO] |  | OOBE | DE |  |  |  | 8064 | The csu inventory was not updated for payload Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}, value of local var is -1
07/22/13 08:14:19:610 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614}
07/22/13 08:14:19:623 | [INFO] |  | OOBE | DE |  |  |  | 8064 | No operation.  We're done:
07/22/13 08:14:21:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Total components installed: 0
07/22/13 08:14:21:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Total components repaired: 0
07/22/13 08:14:21:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Total components removed: 0
07/22/13 08:14:21:635 | [WARN] |  | OOBE | DE |  |  |  | 8064 | DW050: The following payload errors were found during install:
07/22/13 08:14:21:635 | [WARN] |  | OOBE | DE |  |  |  | 8064 | DW050:  - Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All: Install failed
07/22/13 08:14:21:635 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Call PostSession Custom Hook
07/22/13 08:14:21:636 | [INFO] |  | OOBE | DE |  |  |  | 8064 | :: END TIMER :: [Total Timer] took 8922.59 milliseconds (8.92259 seconds) DTR = 19.7252 KBPS (0.0192629 MBPS)
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | -------------------------------------- Summary --------------------------------------
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 |  - 0 fatal error(s), 1 error(s)
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Win OS version: 6.1.1.0 64 bit Type: 1
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ----------- Payload: Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 {48BC197D-7053-434D-AF69-9233170D1614} -----------
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | ERROR: DF022: File corruption detected. Re-install the product & then apply the patch again. (Pre checksum mismatch for file "C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6\ZStringResources\uk_UA.xml")(Seq 3)
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Please search the above error string(s) to find when the error occurred.
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | These errors resulted in installer Exit Code mentioned below.
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | --------------------------------------------------------------------- ----------------
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Exit Code: 7 - Unable to complete Silent workflow.
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | Please see specific errors for troubleshooting. For example, ERROR: DF022 ...
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=*
07/22/13 08:14:22:634 | [INFO] |  | OOBE | DE |  |  |  | 8064 | END - Installer Session
    Jul 28, 2013 9:10 PM   in reply to TDRonline
    exact same issue, but in OS X... and finally, we find common ground in the platform wars.
    RIBS version: 6.0.98.0
    OSX version: 10.8.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 24 milliseconds (0.024 seconds)
    Updated source path: /Users/mjohnson/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManager CS6-6.0/6.0.7
      Type: 0, Volume Order: 1, Media Name: AdobeExtensionManager-6.0.7-mul-AdobeUpdate
      Path: /Users/mjohnson/Library/Caches/Adobe/AAMUpdater/AdobeExtensionManager CS6-6.0/6.0.7/payloads/AdobeExtensionManager6.0All-140713200537/AdobeE xtensionManager6.0All-140713200537.dmg
    Supported RIBS version range: [0.0.66.0,6.0.98.0]
    ----------------- CreatePayloadSession: machine is x86 ---------------
    [       0] Sun Jul 28 20:50:17 2013  INFO
      {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0: 0 (0,0)
    Patch {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 can be applied to product {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6 6.0.0.0
    Value returned on lookup of payload: {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 is: false
    Action string for {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0  is install
    INSTALLDIR passed path basic path validation: /Applications
      {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0:  with operation install
    Calling the custom action code for pre-install for payload {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0
    [       1] Sun Jul 28 20:50:17 2013  INFO
    Payload {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
    [       1] Sun Jul 28 20:50:18 2013  INFO
    Beginning installation for payload at /private/tmp/.tempdir1hOeRgP2/Install.db
    Attempting to patch file: "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources/uk_UA.xml"(Seq 5)
    Attempting to patch file: "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/de.lproj/MainMenu.nib"(Seq 7)
    [       1] Sun Jul 28 20:50:18 2013 ERROR
    DF019: Unable to locate file to patch at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/de.lproj/MainMenu.nib"(Seq 7)
    DW063: Command ARKPatchCommand failed.(Seq 7)
    Completing installation for payload at /private/tmp/.tempdir1hOeRgP2/Install.db
    [       0] Sun Jul 28 20:50:18 2013  INFO
    :: END TIMER :: [Payload Operation :{48BC197D-7053-434D-AF69-9233170D1614}] took 1412 milliseconds (1.412 seconds)
    The csu inventory was not updated for payload {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0, value of local var is -1
    Calling the ROLLBACK custom action code for pre-install for payload {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0
    [       0] Sun Jul 28 20:50:20 2013  INFO
    [       0] Sun Jul 28 20:50:20 2013 ERROR
    :: END TIMER :: [Total Timer] took 5939 milliseconds (5.939 seconds) DTR = 0.673514 KBPS (0.000657729 MBPS)
    - 0 fatal error(s), 3 error(s), 0 warning(s)
    ----------- Payload: {48BC197D-7053-434D-AF69-9233170D1614} Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All 6.0.7.0 -----------
    ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/Resources/de.lproj/MainMenu.nib"(Seq 7)
    ERROR: DW063: Command ARKPatchCommand failed.(Seq 7)
    ERROR: DW050: The following payload errors were found during install:
    ERROR: DW050:  - Adobe Extension Manager CS6_6.0.7_AdobeExtensionManager6.0All: Install failed
    Please search the above error/warning string(s) to find when the error occurred.
    [       0] Sun Jul 28 20:50:21 2013  INFO
    Please see specific errors and warnings for troubleshooting. For example, ERROR: DF019, DW063 ...
    OSX version: 10.8.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 20 milliseconds (0.02 seconds)
    [       1] Sun Jul 28 20:56:12 2013  INFO
    [       1] Sun Jul 28 20:56:14 2013  INFO
    Beginning installation for payload at /private/tmp/.tempdirhgyGsgAN/Install.db
    [       1] Sun Jul 28 20:56:14 2013 ERROR
    Completing installation for payload at /private/tmp/.tempdirhgyGsgAN/Install.db
    [       0] Sun Jul 28 20:56:14 2013  INFO
    [       0] Sun Jul 28 20:56:16 2013  INFO
    [       0] Sun Jul 28 20:56:16 2013 ERROR
    :: END TIMER :: [Total Timer] took 5892 milliseconds (5.892 seconds) DTR = 0.678887 KBPS (0.000662975 MBPS)
    [       0] Sun Jul 28 20:56:17 2013  INFO
    OSX version: 10.8.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 10 milliseconds (0.01 seconds)
    Updated source path: /Volumes/AdobeExtensionManager-6.0.7-mul-AdobeUpdate
      Type: 1, Volume Order: 1, Media Name: AdobeExtensionManager-6.0.7-mul-AdobeUpdate
      Path: /Volumes/AdobeExtensionManager-6.0.7-mul-AdobeUpdate/payloads/AdobeEx tensionManager6.0All-140713200537/AdobeExtensionManager6.0All-14071320 0537.dmg
    Overwrite property "DEVersion" to: 6.0
    [       1] Sun Jul 28 20:59:16 2013  INFO
    [       1] Sun Jul 28 20:59:17 2013  INFO
    Beginning installation for payload at /private/tmp/.tempdir7PKfPN9U/Install.db
    [       1] Sun Jul 28 20:59:17 2013 ERROR
    Completing installation for payload at /private/tmp/.tempdir7PKfPN9U/Install.db
    [       0] Sun Jul 28 20:59:18 2013  INFO
    :: END TIMER :: [Payload Operation :{48BC197D-7053-434D-AF69-9233170D1614}] took 1412 milliseconds (1.412 seconds) DTR = 33.9943 KBPS (0.0331976 MBPS)
    [       0] Sun Jul 28 20:59:20 2013  INFO
    [       0] Sun Jul 28 20:59:20 2013 ERROR
    :: END TIMER :: [Total Timer] took 5694 milliseconds (5.694 seconds) DTR = 6.32244 KBPS (0.00617426 MBPS)
    [       0] Sun Jul 28 20:59:21 2013  INFO
    Jul 31, 2013 1:01 AM   in reply to fadedgiant
    All the errors seem to be an update issue with Extension Manager.
    Can you check if Fireworks version is updated to 12.0.1 in Help > About Fireworks on Windows and Fireworks > About Fireworks on Mac?
    If it is updated, then the update was successful. (CS6 version is 12.0.0.236. Updated version is 12.0.1)
