Samsam789
Graphics in premiere pro
Jul 23, 2013 3:31 AM
Tags: #after_effects #premiere_pro #quality #graphic
I am making a graphic video for the first time. It is a doll, and I want its arms and legs to move seperately. I created the doll in Adobe illustrator (is that already a mistake?). And saved it as an .ai file. Then imported it into after effects and made the movements. Checked the box: continuously rasterize and then rendered the movie clip.
Imported the movie clip into Premiere Pro and added sound. But here the quality was some much lower then when I first created the vector into Illustrator. What did I do wrong or what didn't I do? Any tips?
  • Jon-M-Spear
    Jan 27, 2006
    Jul 23, 2013 4:24 AM   in reply to Samsam789
    You need to look at the export settings.  You may be using a lossy codec which will have an impact on the output quality.
    What settings did you use to export it from AE and PP?
    Jul 23, 2013 8:52 AM   in reply to Samsam789
    How will it be delivered?
    Jul 23, 2013 11:59 AM   in reply to Samsam789
    Just use dynamic link so you dont have to worry about lossy rendering.
    Jul 24, 2013 3:16 AM   in reply to Samsam789
    Avi is not small
    I would go for wmv for Powerpoint.
    Jul 25, 2013 4:26 AM   in reply to Ann Bens
    Some versions of Powerpoint (windows) only take WMV or MPEG1. Mac powerpoint, only seems to like MPEG1 and MP4 files. Newer versions of Powerpoint may be different.
    Jul 25, 2013 4:44 AM   in reply to Samsam789
    It's most likely an issue with your sequence / composition settings (Resolution, fps, and progressive/interlaced ). Make sure they are the same throughout.
    In AE: Composition settings & Render setting
    In PP: Sequence settings & Render setting
    Premiere Pro can automatically create the sequence with the right settings using the rendered AE file. Just select New - > sequence from clip.
    And when rendering, make use the input & output settings are the same.
    Hope this helps.
