'Help cannot search for that phrase'
Jul 23, 2013 4:40 AM
Tags: #9 #search #xml #robohelp #chm
I am getting the message 'Help cannot search for that phrase' while searching for 'xml' in a chm (generated using RH9). The old CHM (generated using RH8) shows the results for the keyword xml. Is this a known issue? Any workaround to resolve this issue?
    Jul 25, 2013 11:20 AM   in reply to pkaslam
    I just tried in a Rh10 project and got the same result in a CHM but not in WebHelp, there the search worked so I suspect it is something in the Microsoft Help Compiler.
    There is a solution if you can upgrade to Rh10. That allows you to generate WebHelp and then convert it to a skinned CHM. I just tried that and there the search worked in the CHM.
    @petergrainge
