Mahueles
How can I create an "exit" pop up in Flex Mobile?
Jul 23, 2013 10:27 AM
Tags: #skinnablepopupcontainer #flex #mobile #popup
Ok, I'm creating an app that has an "exit" button in all views, and when that button is clicked the only thing that I do is use "navigator.popToFirstView()", this works perfect, but I don't want people to exit right away, I want to have a pop up that asks if you are sure you want to exit, below is the code that I have for the skinnable pop up container:
<fx:Script>
                         <![CDATA[
                                             import mx.events.FlexEvent;
                  protected function yesExit(event:MouseEvent):void
                                                            this.close();
          </fx:Script>
          <s:VGroup>
                         <s:Label text="Are you sure you want to exit?" width="100%"  />
                         <s:HGroup width="100%" horizontalAlign="center" >
                                        <s:Button label="Yes" click="yesExit(event)" width="40%"  />
                                        <s:Button label="No" click="this.close()" width="40%"  />
                         </s:HGroup>
          </s:VGroup>
I tried using something like "parent.poptofirstview" but that doesn't work, and right now I'm stuck. Any help would be appreciated. thanks!
    Jul 24, 2013 6:40 PM   in reply to Mahueles
    You need to add an event listener for PopUpEvent.CLOSE on whatever view is creating the pop up.  Then in the handler for that listener, you can do a navigator.popToFirstView()  You'll also have to pass some type of data along with the close event so that you'll know whether the window was closed because "yes" was selected or "no".
