ishibashik
When using line tools the keyboard shortcuts such as spacebar don't work.
Jul 24, 2013 2:35 PM
Tags: #illustrator #problem #help #tool
Is there a setting that I need to change to facilitate this?  This is also true in my shapes...
    Jul 24, 2013 2:39 PM   in reply to ishibashik
    Are you using Illustrator 10?
    Jul 24, 2013 3:31 PM   in reply to ishibashik
    The Line tool is nearly as useless as the Arc tool.
    You would do better to use the Pen tool with all its possibilities.
    Jul 24, 2013 6:32 PM   in reply to ishibashik
    The Line Tool makes a far better measuring tool than the Measure Tool.
    The Line Tool also lets you define a single-segment straight path in terms of length and angle in one step--a basic and critical need.
    JET
    Jul 25, 2013 12:11 PM   in reply to ishibashik
    Assuming you've also got InDesign: Do you see the same issue there?
    Jul 25, 2013 12:23 PM   in reply to Steve Fairbairn
    The question was not whether the line tool was useful, it was "why do the shortcuts not work"?
    This is a long-shot, but I've noticed if I assign a custom keyboard shortcut, using the "Keyboard Shortcuts" menu and inadvertantly type a shortcut that's already in use, AI disables the original shortcut even if I choose a different shortcut for the current tool. Just today I had to go back and re-assign some shortcuts in AICS5 after this happened.
    BTW… I use the line tool to good effect regularly. To each his/her own.
    Jul 25, 2013 12:49 PM   in reply to ishibashik
    No problem with the shortcuts here.
    Which system do you use?
    What kind of keyboard and mouse?
    A Wacom?
    As this is kind of related: what happens if you shut down apps that make an internet connection - like browsers, e-mail ...
    Jul 26, 2013 1:38 PM   in reply to ishibashik
    Ishibashi,
    You may try to open possible troublemaking applications to find the guilty one(s) so you can have the others running.
    This is the current list of the usual suspects collected from this forum (additions are very welcome):
    (the list will be updated):
    • Quicktime/iTunes,
    • Quicken (Widget),
    • Entourage,
    • Google Earth,
    • Zune,
    • Some Firefox Add-ons,
    • Spotlight (shortcuts),
    • Fetch,
    • Hulu,
    • Cocktail,
    • Cinch,
    • RightZoom,
    • BetterTouch,
    • Anti virus software,
    • Synergy
    • FontExplorer:
    Jul 28, 2013 6:26 AM   in reply to ishibashik
    You are welcome, Ishibashi.
