Is it possible to open another application from a photoshop extension?
Jul 25, 2013 5:01 PM
Tags: #photoshop #adobe #builder #cs_extention_builder
I'd like to call an application from a photoshop extension including a parameter (ie "c:\path\myApplication.exe -p paramvalue".  I can see this can be done in AIR - but not found anything within a photoshop extension.  Am I missing something?  Is it possible?
    Jul 26, 2013 1:29 AM   in reply to wizbowes
    If you want to launch another Creative Suite then you can refer to the CS Communication Toolkit available in Extension Builder (Choose help > CS Extension Builder Extras). Otherwise please refer to the AIR APIs such as NativeProcess and openWithDefaultApplication.
    Kind regards,
    Lea
    Jul 26, 2013 6:15 AM   in reply to wizbowes
    Not if you are building a CS Extension. You can use a number of AIR APIs in a CS Extension including Native Process.
    Jul 29, 2013 2:09 AM   in reply to wizbowes
    Are you writing a CS Extension in AIR? Or are you writing a native plugin in C++?
    If the former then you can just add the import statement where required and use the APIs. For example:
    <csxs:CSExtension xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:csxs="com.adobe.csxs.core.*">
    <fx:Script>
    <![CDATA[
      import flash.desktop.NativeProcess;
      import flash.desktop.NativeProcessStartupInfo;
      import flash.filesystem.File;
       private
    function triggerNativeProcess():void  {
        var process:NativeProcess = null;
        var executable:File = new File("C:\\Windows\\system32\\notepad.exe");
        startNotepadCmd(executable);
      protected
     static function startNotepadCmd(notepadCmd:File):void
        var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();    nativeProcessStartupInfo.executable = notepadCmd;
        nativeProcessStartupInfo.workingDirectory = notepadCmd.parent;
        process =
    new NativeProcess();
        process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, onNativeProcessOutputData,
    false, 0, true);    process.addEventListener(ProgressEvent.STANDARD_ERROR_DATA, onNativeProcessErrorData,
    false, 0, true);    process.addEventListener(NativeProcessExitEvent.EXIT, onNativeProcessExit,
    false, 0, true);
        process.start(nativeProcessStartupInfo);
    </fx:Script>
    </csxs:CSExtension>
    Kind regards,
    Lea
