deeve5603
Project Presets For Editing .mov 720P
Jul 29, 2013 9:01 PM
Hello, I have Drift Inovations 170HD Stealth that I would like to edit in PE11.  The camera specs show that it records 1080P and 720P in .mov (h.264) format.  What would be the best Project Setting for that?
Thanks!
DAVE
    Jul 29, 2013 9:13 PM   in reply to deeve5603
    These two links may help
    Importing Video http://forums.adobe.com/thread/1065281
    -and project settings http://forums.adobe.com/thread/1112086
    Jul 30, 2013 12:03 AM   in reply to deeve5603
    I'd recommend that you use the project preset for Flip Mino HD.
    Premiere Elements usually sets your project settings automatically, but can have trouble reading the specs on MOV files.
    Jul 30, 2013 6:19 AM   in reply to deeve5603
    Dave,
    What is your camera set for, NTSC or PAL?
    And what are the frame rates involved:
    for 1080p
    for 720p
    Your camera seems to be offering
    for 1080p, 25 or 30 frames per second
    for 720p, 25, 30, 50, or 60
    Do not depend on the Premiere Elements 11 automatic project preset selection for any format. Always verify with Edit Menu/Project Settings/General Editing Mode, Timebase, Frame Size to see what the program has set after your first video drag to the Timeline. If it agrees with the properties of your source media, fine. But, if not, set the project preset yourself manually before you import the file. (See File Menu/New/Project and "Force Selected Project Setting on this Project".
    ATR
    Jul 30, 2013 6:38 AM   in reply to deeve5603
    Dave,
    Premiere Elements 11 uses as its default project preset
    for NTSC, NTSC AVCHD AVCHD HD1080i30
    for PAL, PAL AVCHD AVCHD HD1080i25
    You can check that out by going to Edit Menu/Project Settings/General to see what is shown for Editing Mode, Timebase, and Frame Size.
    That default remains until you drag your first video to the Timeline. When you do that, the program is supposed to analyze your video's properties and give you the project preset that is correct for that specific video. Sometimes it does, and sometimes it does not.
    If you supply the information requested for video recording frame rates, I will suggest project presets for your editing of your video in Premiere Elements 11.
    Thanks.
    ATR
    Add On..In the good old days prior to Premiere Elements 11, the default project preset was NTSC DV Standard or PAL DV Standard depending on whether you had a NTSC or PAL setup.
    Jul 30, 2013 7:49 AM   in reply to deeve5603
    Dave
    Based on your H.264.mov source....
    For the 1080p60
    I would use NTSC AVCHD AVCHD 1080p60
    For the 1080p30
    I would use NTSC DSLR 1080p DSLR 1080p30
    For 720p30
    I would use NTSC AVCHD AVCHD LITE 720p30
    For 720p60
    I would use NTSC AVCHD AVCHD LITE 720p60
    Important issue in setting the project preset and seeking match with video properties is having the program establish the correct space in the edit mode monitor for editing purposes.
    Please review and do not hesitate to ask for clarification on anything that I write.
    Thanks.
    ATR
    Jul 30, 2013 9:40 AM   in reply to deeve5603
    deeve5603
    Definitely, have a check mark next to Force Selected Project Setting on this Project" before you exit the new project dialog after you change the project preset.
    Only then import your video into the project with Add Media.
    Looking forward to your results.
    Thank you.
    ATR
    Jul 30, 2013 12:51 PM   in reply to deeve5603
    Dave,
    Here is something to start you with for your exports...wth regard to your 1080p60
    Publish+Share
    Computer
    AVCHD
    Presets = MP4 - H.264 1920 x 1080p30
    Then click on the Advanced Button for this preset and customized the settings as shown in a partial view of the Export Settings dialog.
    After a first look, you can adjust BItrate Settings if needed.
    We can go into more export settings for the other file formats when you are ready.
    Looking forward to your results. Sounding good.
    Thanks.
    ATR
    Jul 30, 2013 6:03 PM   in reply to deeve5603
    Dave,
    That was very good news.
    For the 720p25, 720p30, and 720p60, I would look at:
    For 720p60
    Publish+Share
    Computer
    AVCHD
    with Presets = MP4 - HD 720p60
    (Refer to details in screenshot below)
    For 720p30
    Publish+Share
    Computer
    AVCHD
    (but in this case, you are going to go under the Advanced Button/Video Tab and change the frame rate from 60 to 30.
    For 720p25
    Publish_Share
    Computer
    AVCHD
    (but in this case, you are going to go under the Advanced Button/Video Tab and change the frame rate from 60 to 25.
    720p60
    720p30
    720p25
    The choice of 59.94 vs 60 and 29.97 vs 30 often depends of details from your camera. But see how you do with the suggested settings.
    Thanks.
    ATR
