codecreator10
Shape Builder tool
Jul 30, 2013 9:12 PM
Tags: #fill #shape_builder_tool #solid_shapes
Hey all!
I am working on a logo that has an anchor in it. I drew the anchor myself using the pen tool, straight line tool, and eliptical tool. It appears that everything is smoothly connected and I have rounded out the corners of my anchor, and also put a round cap on my adjoining lines.
I then highlighted the whole anchor and pressed cmd+J (I am working on a Mac) to join all the edges in an attempt to make the anchor one whole shape, which I intend to fill one solid color.
However, when I use the shape builder tool, Illustrator does not recognize my anchor as one solid shape. When you hover your mouse over a solid shape, the Shape Builder tool has a dotted pattern inside your shape. This is not happening in my anchor. I painstakingly went over each "joint" and made sure that they were connected, with no avail.
There has to be something I am missing here.. Anyone have any suggestions? They are much appreciated!
Thanks in advance.
    Jul 30, 2013 9:21 PM   in reply to codecreator10
    Have you viewed it in the Layers Panel? This is the easiest way to see how many paths really exist.
    You could also convert the selection to a Live Paint object and then fill it with the Live Paint Bucket tool.
    Jul 31, 2013 1:33 AM   in reply to codecreator10
    When you select the anchor and look into Layers panel, it should be listed as a single object. Also can you check if the object is not grouped or clipped etc.
    Aug 1, 2013 2:01 PM   in reply to codecreator10
    - Which version of Illustrator?
    - Can you provide a sample .ai file?
