Rohini_1327
Checkbox itemrender of Advanced grid does not hold proper selections on next open event of tree in F
Jul 31, 2013 12:34 AM
Tags: #flex #actionscript #itemrenderer
I have a checkbox in AdvancedDataGrid as GroupItemrenderer.I have  selected certain child nodes in tree and closed its parent,later when I  reopen the same parent node,selected child nodes are not those that i  selected.How to retain the correct selections in checkbox.??
Also am unable to set the value for checkbox (GroupItemRenderer) by default from component and also unable to access the value for checkbox in Data property.
I am using 2D array as dataprovider to ADG.
package
import flash.events.KeyboardEvent;
import flash.events.MouseEvent;
import flash.ui.Keyboard;
import mx.collections.ICollectionView;
import mx.collections.IHierarchicalCollectionView;
import mx.collections.IHierarchicalData;
import mx.collections.IViewCursor;
import mx.controls.AdvancedDataGrid;
import mx.controls.Alert;
import mx.controls.CheckBox;
import mx.controls.Image;
import mx.controls.advancedDataGridClasses.AdvancedDataGridColumn;
import mx.controls.advancedDataGridClasses.AdvancedDataGridGroupItemRenderer;
import mx.controls.advancedDataGridClasses.AdvancedDataGridListData;
import mx.core.FlexGlobals;
import mx.core.mx_internal;
use namespace mx_internal;
public class CheckADGRenderer extends AdvancedDataGridGroupItemRenderer
protected var myImage:Image;
public var status:String = "false";
// set image properties
private var imageWidth:Number   = 6;
private var imageHeight:Number  = 6;
private var inner:String    = "inner.png";
protected var myCheckBox:CheckBox;
static private var STATE_SCHRODINGER:String = "schrodinger";
static private var STATE_CHECKED:String = "checked";
static private var STATE_UNCHECKED:String = "unchecked";
public function CheckADGRenderer ()
super();
        mouseEnabled
= false;
private function toggleParents(item:Object,adg:AdvancedDataGrid,state:String):void
if (item == null)
return;
else
            item
.@state = false;
            toggleParents
(adg.getParentItem(item), adg, getState (adg, adg.getParentItem(item)));
private function toggleChildren (item:Object, adg:AdvancedDataGrid, state:String):void
if (item == null)
return;
else
//item.@state = state;
var adgCollection:IHierarchicalCollectionView = adg.dataProvider as IHierarchicalCollectionView;
var adgHD:IHierarchicalData = adgCollection.source;
if (adgHD.hasChildren(item))
var children:ICollectionView = adgCollection.getChildren (item);
var cursor:IViewCursor = children.createCursor();
while (!cursor.afterLast)
                    toggleChildren
(cursor.current, adg, state);
                    cursor
.moveNext();
private function getState(adg:AdvancedDataGrid, parent:Object):String
var noChecks:int = 0;
var noCats:int = 0;
var noUnChecks:int = 0;
if (parent != null)
var cursor:IViewCursor = adgCollection.getChildren(parent).createCursor();
if ((noChecks > 0 && noUnChecks > 0) || (noCats > 0))
return STATE_SCHRODINGER;
else if (noChecks > 0)
return STATE_CHECKED;
else
return STATE_UNCHECKED;
private function imageToggleHandler(event:MouseEvent):void
        myCheckBox
.selected = !myCheckBox.selected;
        checkBoxToggleHandler
(event);
var selectArr:Array = new Array();
private function checkBoxToggleHandler(event:MouseEvent):void
if (data)
var myListData:AdvancedDataGridListData = AdvancedDataGridListData(this.listData);
var selectedNode:Object = myListData.item;
var adg:AdvancedDataGrid = AdvancedDataGrid(myListData.owner);
var toggle:Boolean = myCheckBox.selected;
if (toggle)
                toggleChildren
(data, adg, STATE_CHECKED);
else
                toggleChildren
(data, adg, STATE_UNCHECKED);
var parent:Object = adg.getParentItem (data);
            toggleParents
(parent, adg, getState (adg, parent));
//Alert.show(selectArr.toString()+"\t\t"+selectArr.length+"\t\t"+selectArr[0].length+"\t\t"+adg.selectedIndices.length);
override protected function createChildren():void
super.createChildren();
        myCheckBox
= new CheckBox();
        myCheckBox
.setStyle( "verticalAlign", "middle" );
        myCheckBox
.addEventListener( MouseEvent.CLICK, checkBoxToggleHandler );
        addChild
(myCheckBox);
private function setCheckState (checkBox:CheckBox, value:Object, state:Boolean):void
if (state == STATE_CHECKED)
            checkBox
.selected = state;
else if (state == STATE_UNCHECKED)
            checkBox
.selected = false;
else if (state == STATE_SCHRODINGER)
            checkBox
.selected = false;
        checkBox
.selected = state;
override public function set data(value:Object):void
super.data = value;
//var adg:AdvancedDataGrid = AdvancedDataGrid(myListData.owner);
        myCheckBox
.selected =  AdvancedDataGridListData(super.listData).item.show;
//setCheckState (myCheckBox, value, Boolean(value.state));
override protected function commitProperties():void
super.commitProperties();
var dg:AdvancedDataGrid = AdvancedDataGrid(listData.owner);
var column:AdvancedDataGridColumn =
           dg
.columns[listData.columnIndex];
       label
.wordWrap = dg.columnWordWrap(column);
     *  @private
override protected function measure():void
super.measure();
var w:Number = data ? AdvancedDataGridListData(listData).indent : 0;
if (disclosureIcon)
            w
+= disclosureIcon.width;
if (icon)
            w
+= icon.measuredWidth;
if (myCheckBox)
            w
+= myCheckBox.measuredWidth;
// guarantee that label width isn't zero because it messes up ability to measure
if (label.width < 4 || label.height < 4)
            label
.width = 4;
            label
.height = 16;
if (isNaN(explicitWidth))
            w
+= label.getExplicitOrMeasuredWidth();
            measuredWidth
= w;
else
            label
.width = Math.max(explicitWidth - w, 4);
        measuredHeight
= label.getExplicitOrMeasuredHeight();
if (icon && icon.measuredHeight > measuredHeight)
            measuredHeight
= icon.measuredHeight;
if (myCheckBox && myCheckBox.measuredHeight > measuredHeight)
            measuredHeight
= myCheckBox.measuredHeight;
override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
super.updateDisplayList(unscaledWidth, unscaledHeight);
if(super.data)
if (super.icon != null)
                myCheckBox
.x = super.icon.x;
                myCheckBox
.y = (unscaledHeight - myCheckBox.height) / 2;
super.icon.x = myCheckBox.x + myCheckBox.width + 17;
if (icon.x + icon.width > unscaledWidth)
                    icon
.setActualSize(0, unscaledHeight);
super.label.x = super.icon.x + super.icon.width + 3;
super.label.setActualSize(Math.max(unscaledWidth - super.label.x, 4), unscaledHeight);
else
                myCheckBox
.x = super.label.x;
                myCheckBox
super.label.x = myCheckBox.x + myCheckBox.width + 17;
if (myCheckBox.x + myCheckBox.width > unscaledWidth)
                myCheckBox
.visible = false;
        trace
(label.width);
The above is my GroupItemrenderer.
    Aug 10, 2013 9:16 PM   in reply to Rohini_1327
    Checkbox selection value should be updated on the underlyng data object. In the override set data method, update the selection based on the value from the data object
