mrdakota
Table Content Disappears
Aug 2, 2013 5:51 AM
I am using Tech Suite 4/Frame 11 on Windows 7. Why do I have table content disappear and reappear at times? When I zoom up, at times only partial content appears. Also, in the images below, the first is 100%, the second is 120% and the third is 140%. When I zoomed up to 120%, the content partially appeared, but when I started to scroll to the right to view this table better, the content totally disappeared. What is going on? Is this another bug with Adobe? It is frustrating wondering what may be in the table for content when it comes to outputting to PDF or making updates.
    Aug 2, 2013 6:33 AM   in reply to mrdakota
    Does the issue go away when you refresh (Ctrl-L)? FM sometimes has issues with displaying text fast enough
    Aug 2, 2013 6:52 AM   in reply to mrdakota
    Your 100% view shows greeked text, which means your preferences are set to *not* display type at or below that point size.
    Aug 2, 2013 7:00 AM   in reply to mrdakota
    You're saying that after increasing the greek text setting that your 100% view is the same???
    Aug 2, 2013 8:42 AM   in reply to mrdakota
    Have you specified your monitor size in the Preferences or is it set at the "default" value?  This also affects how FM tries to set the display at zoom values.
    Note: the drop-down list for the monitors one of the "special" drop-downs where you can also enter a specific value instead of just picking the values presented. There is no special visual indicator that you can do this.
