Can you retain ram preview of comp after minor change?
Aug 2, 2013 9:35 AM
AE v12-CC
is there a way to ram preview a comp.....make a minor adjustment and then only have to render what was revised, so that you retain the rest of the ram preview of the unchanged area?
    Aug 2, 2013 11:34 AM   in reply to philc452
    The entire frame must be rendered so if you changes involve the entire layer then the layer must be rendered. However, with CS6 and CS, if you make a change that only effects frame 20 thru frame 50 then only that part must be re-rendered. This functionality is better in CC than in CS6. Before CS6 all frames must be re-rendered for a preview.
    Aug 2, 2013 5:10 PM   in reply to Rick Gerard
    See this video for details about how the caching system works in After Effects CS6 and later:
    http://bit.ly/KjtjYa
