Recompiling framework.swc
Aug 3, 2013 8:28 AM
Tags: #air #flex-mobile #flex4.6
In order to solve the DPI problem (see my last topic),I decided to see the sdk source code.
I found changing systemManager.as , DensityUtils.as ,  RuntimeDPIProvider.as and DPIClassification.as file is the key to my problem ,so I changed the classifyDPI method in RuntimgDPIProvider.as file :
mx_internal static function classifyDPI(dpi:Number):Number
        if (dpi < 200)
            return DPIClassification.DPI_160;
        if (dpi <= 280)
            return DPIClassification.DPI_240;
//   ↓↓    ↓↓  ↓↓ I changed  this ↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓
          if(dpi <= 360)
             return DPIClassification.DPI_320;
          return DPIClassification.DPI_400;
then I added DPIClassification_DPI_400 = 400 in DPIClassification.as file
In DensityUtils.as , I changed the getDPIScale method like this:
public static function getDPIScale(sourceDPI:Number, targetDPI:Number):Number
        // Unknown dpi returns NaN
        if ((sourceDPI != DPIClassification.DPI_160 && sourceDPI != DPIClassification.DPI_240 &&
  sourceDPI != DPIClassification.DPI_320 && sourceDPI != DPIClassification.DPI_400||
            (targetDPI != DPIClassification.DPI_160 && targetDPI != DPIClassification.DPI_240 &&
  targetDPI != DPIClassification.DPI_320 && targetDPI != DPIClassification.DPI_400))
            return NaN;
        return targetDPI / sourceDPI;
Now it seems that  I can handle DPI problem by changing all these files.
BUT,there's a new problem, I have to recompile  framework.swc file to get these things work. If anyone have done this before?
If these methods can be overrided in my application ,then how ?
    Aug 3, 2013 9:25 AM   in reply to hubcin
    Google this:
    ActionScript "Monkey Patch"
    Much easier than recompiling the Flex source.
    Aug 5, 2013 10:03 AM   in reply to hubcin
    Hello, hubcin.
    I have the same problem than you, good although I see you've solved ...
    Can you give me specific instructions how i must to do?
    Thank you.
    Best Regards.
    Aug 6, 2013 8:24 AM   in reply to hubcin
    Ok. First many Thanks for your patience.
    But I need to put all the code in SystemManager.as, and for the other: DensityUtils.as ,  RuntimeDPIProvider.as and DPIClassification.as and after make your corrections?
    Can yo send me by email this folder.
    I will be obliged greatly.
    Thank you again.
    Aug 6, 2013 10:21 AM   in reply to hubcin
    Many, many Thanks.
    It works perfectly.
    Now I must to do all the modifcations in App (resources), but detection of DPI works correctly.
    Best Regards and Thank you again.
    Aug 6, 2013 11:35 AM   in reply to mfdezpo
    There is another thing to do and is to modify MultiDPIBitmapSource.as inside spark/utils the same mode.
    Note: There is a small error in name of DensityUtils.as -> DensityUtil.as at the beginning of post.
    Thanks a lot again.
