Bellular
AVI - Audio Only, No Video
Aug 3, 2013 4:13 PM
The file plays perfectly in VLC however its running into problems with Premiere. When I import the AVI it only imports the audio. I tired to get around this by using a batch file to change the wrapped to mp4, however the video appears as a green screen on the source and preview windows.
I am kind of at a loss currently. Ive asked the client for the camera model.
Here is the information from mediainfo
General
Complete name                            : E:\Work\Order 2\IMAG8103.AVI
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 329 MiB
Duration                                 : 5mn 39s
Overall bit rate mode                    : Variable
Overall bit rate                         : 8 152 Kbps
Recorded date                            : 2009-02-12
Writing library                          : AMBA
ICRT                                     : 12:31:41
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L4.0
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Format settings, GOP                     : M=1, N=8
Codec ID                                 : H264
Duration                                 : 5mn 39s
Bit rate mode                            : Variable
Bit rate                                 : 8 001 Kbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 29.970 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.129
Stream size                              : 324 MiB (98%)
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : FF
Duration                                 : 5mn 38s
Bit rate                                 : 128 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Compression mode                         : Lossy
Stream size                              : 5.17 MiB (2%)
Alignment                                : Split accross interleaves
Interleave, duration                     : 21 ms (0.64 video frame)
