• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
VDP using PDF as Input
Explorer ,
Aug 06, 2013 Aug 06, 2013
Adobe planned  for printer manufacturer to use PDF Engine few years back
Finally now you start see large digital printer manufactures like Xerox is releasing color 70+ Pages Per Minute print engine support PS 3  and PDF side by side.
This is new for 2013!
And it is expected to increase to all ranges of printers and all vendors.
Does anybody see VDP/personalization applications developed which based on accepting data stream as PDF !
I know PlanetPress and GMC now supporting PDF input data stream side by side as raw data
However I still see speed , more feature and control can only acheive if the data stream is raw data
e.g. Text , ASCII , EBCDIC , CSV , TAB Delimited   and XML
Cheers
Adam.
TOPICS
Programming
Views
3.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
You should investigate PDF/VT, an ISO standard for using PDF for representation of VDP content. The DNA of PDF/VT is use of Forms XObjects, Image XObjects, and Reference XObjects for repeated content and for caching of such rendered XObjects by the RIP / DFE software to optimize throughput.
At Print'13 in Chicago in September, you will see release of the very graphically-rich CalPoly GrC PDF/VT-1 application test files which are great for testing implementations of direct PDF RIPs supporting PDF/VT optimization!
XMPie has an excellent PDF/VT generation capability built on top of InDesign for both desktop or server. Other vendors are also now rolling out PDF/VT support.
PostScript, PPML, and the various vendor-proprietary solutions should become dead issues when dealing with graphically-rich, color-managed with live transparency VDP workflows in the future!
          - Dov
             (chair TC130 WG2/TF2 - PDF/X
              and co-chair TC130 WG2/TF3 - VDP & PDF/VT)
- Dov Isaacs, former Adobe Principal Scientist (April 30, 1990 - May 30, 2021)
Votes
Translate
Translate
Report
Report
Explorer ,
It is no doubt that PDF/VT will grow and improved and by time more applications will developed using this relatively new technology
Still a question that most of the systems - heritage- even newly developed applications - specially in high volume output are prodcuing output as text , CSV, and of course XML !!
And these format neww Postscript to handle the personalization and VDP!
If these system applications produced PDF - as most of it has tools to produce PDF but also they have tools within it to provide simple VDP and then no need for second step VDP software e.g. PDF/VT to handle the formatting!
I am not defending postscript!
As I am sure the future will be for PDF/VT    but PDF engine is released in 2006 !
Only in 2012 Software developer start to implement it !
Only in 2013 Printer manufacturers started to use it seriously and not solely but side by side with PS 3 ! as you can see it took them more than them 6 years to do that!
So when do you think they will abandon Postscript totally and it will be died as you said !!   may be within another more 6-8 years     unless one printer manufacture or software company will develop PS 4 with ICC profiling and layering  etc
You mentioned that Adobe will not do it.
Ironically still Adobe Postscript the most famous , most important programing language across the last 15-20 years compared to the effort invested in it and other computer languages!
I mean Adobe never put any engineering in postscript since year 2000!!  the latest documentation/revision is dated 2000 !
Can you think where C++ or C#  will be if development stopped for two years !  may be 10th of languages died over the last 10-15 year   but still Postscript released  in each print device and implemented in all VDP software!
Adobe created a miracle called Postscript and only Adobe can kill it  but no so fast
Dr.  Adam
Votes
Translate
Translate
Report
Report
To be very clear:
(1)     The “high volume output” systems you refer to are not outputting simple text, CSV, and XML for VDP unles all they are printing is plain text on top of pre-printed shells. If you are referring to something like PPML, it turns out that PPML may be based on XML but all its graphics are other file formats including TIFF and JPEG raster formats as well as EPS and PDF. Effectively, all such formats that allow EPS and PDF graphics are currently converted to PostScript.
(2)     Actually, software developers (including XMPie and HP) were well into developing PDF/VT output in 2011. The PDF/VT standard wasn't even published by ISO until 2010!
(3)     I never talked about the death of PostScript but rather, that its use for graphically rich VDP will become a dead issue, although it will take a while.
(4)     As previously mentioned in other posts, there will not be any further development of the PostScript language. ICC color management and transparency will never be part of the PostScript imaging model. And if Adobe won't do that, I can assure you no one else will because simply, there is no perceived value to it!
(5)     You personally have no knowledge of what engineering work Adobe has done or not done for PostScript either prior to or after 2000. In fact, Adobe still has a sustaining engineering group that works on our PostScript implementation for our OEM partners who have PostScript products, especially in the desktop printing arena.
(6)     There is no question that PostScript was a major achievement for the printing and graphic arts industry, not only technically, but because it arrived at a time at which Adobe was able to convince a wide array of printer device manufacturers to adopt it instead of continuing to pursue proprietary solutions. It is questionable whether such a feat could be accomplished today. In 1984-85, the circumstances happened to be just right and between QMS, Linotype, and then Apple, we got the right mix and threshold of early and influencial adopters to make PostScript and its ecosystem successful.
FWIW, Cobol programs are still around and thriving!
          - Dov
Votes
Translate
Translate
Report
Report
Explorer ,
XMpie , and Planet Press and GMC  all announced support of VDP using PDF as input format ,  I saw for the first time in Drupa complete presentation to Restructure and format PDF by Planet Press !
Still  using input raw format like Text , CSV , XML and use Postscript for formatting will give  much more speed and great more features in formatting than using PDF/VT.  - it was even confirmed through the presentation !
Most large systems systems like Billing , Invoicing , Core Banking can output in any way you want , text , CVS, Tab Delimited , XML and also PDF !   it is faster and require no additional programming to output in CSV or XML (widely preferred) not PPML  but just XML , tags  without any image or graphics.
Then user can use on the famous VDP package as I mentioned to generate fully formatted output.
I never heard or see large of those systems generate PDF which will be formatted later!
In fact all of Telecom company produce complicated XML which require advanced formatting software.  Pres  e.g.
When I said Adobe never put any engineering I meant development!    Of course the support and liaison with manufacturer and OEM will remain.   Every desktop laser Printer up to digital press in the world has PS built in or an option !!
FWIW, Cobol programs are still around and thriving! "    it is true simply  because many small/enterprise business and financial applications were developed using Cobol and it is still good enough to do the job! vendors don't want to rewrite the entire system
I still see Core Banking Systems written totally in Cobol and just have Oracle or Sybase as DB Engine!! long live Cobol!
It is needed and it can do the job without new release of Cobol.
Perhaps this is might be a point to you too !!   As All RIP manufacturers  Like EFI , Creo , and newly arrived like Xerox , Konica Minolta  had invested millions of dollars over the last 20 years to provide Rip based on Postscript with its color management   etc !
All Software vendors for VDP had also invested millions of dollars to create their software based on Postscript programming!
Last but not the least , many end users had created their work and training using famous VDP packages which is based on input raw data (CSV , Text , Records, XML , EBCDIC  etc )  and Postscript as formatting language..
These will extend postscript life as formatting language  --  what do you think ?
Cheers
Dr. Adam
Votes
Translate
Translate
Report
Report
Exactly what additional formatting features do you think Text, CSV, and XML with PostScript can give you when in fact PostScript is in fact has only a subset of the PDF imaging model?
Strictly speaking, those systems you refer to print “variable data” just as every data processing program back to the days of the earliest business applications did on such dinosaur equipment as IBM 1403N1 line printers with streams of EBCDIC characters and carriage tape controls. And that's exactly the type of printing that is gradually but surely going away. For that transactional material, PDF/VT is certainly usable, but may be overkill. But when we talk about VDP these days, we generally are referring to personalized marketing materials that have minimal if any transactional data but are very graphically-rich and simply cannot readily be expressed with the page description languages or the protocols you enumerate.
When I said Adobe never put any engineering I meant development!    Of course the support and liaison with manufacturer and OEM will remain.   Every desktop laser Printer in the world has PS built in or an option !!
Adobe does have “engineering resource” working on our PostScript implementation albeit not new language features.
Perhaps this is might be a point to you too !!   As All RIP manufacturers  Like EFI , Creo , had invested millions dollars over the last 20 years to provide Rip based on Postscript with its color management   etc !
Creo no longer exists other than the remnants of a brand name. Creo was acquired by Eastman Kodak a number of years back. Both EFI and Kodak are actively investing in Adobe PDF Print Engine support for PDF/VT. PostScript for them, like most of our OEMs is pretty much a maintenance issue.
All Software vendors for VDP had also invested multi million dollars to create their systems based on raw data input to Postscript engine!
And they are all now investing primarily in supporting PDF/VT output because simply stated, they can't get all those great graphics effects that they can generate to print otherwise!
Last but not the least , many end users had created their work and training using famous VDP packages which is based on input raw data (CSV , Text , Records, XML , EBCDIC  etc )  and output to Postscript.
It is totally irrelevant what the raw input is to the VDP packages (such as XMPie, Darwin, DirectSmile, etc.). Certainly those will continue to be either direct database links or CSV, plain old text, XML, etc. Users who are trained to input such data to VDP packages don't need to be retrained for PDF/VT output. In fact, for most printers, handling PDF/VT will be much easier than other formats since it enforces a single, common PDF print publishing workflow including support for viewing, preflighting, proofing, etc. How in the world do you preflight PostScript, PPML, or any of the other formats other than perhaps ... converting them somehow to PDF?!?
          - Dov
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 07, 2013 Aug 07, 2013
Yes the imaging model in PDF has more features.
But postscript commands have full capability of programming language features while PDF commands are marking type commands.
This give more control to build conditional insertion of text , images based on logical variable and fields in the data stream at different locations  , in simple words  Postscript can build more complex document with VDP intense of graphics and text.
Any way I am sure the difference will be reduced if Adobe continue on developing PDF/VT technology and keeping the PS with the same features as in year 2000 without any increase.
Unless third party vendor took the investment for PS 4  which is most probably could happen -   but you made it clear Adobe will not doing it.
VDP software companies have already introduced their products in 2012 supporting PDF input data stream. up to my knowledge GMC and PlanetPress. and Xerox as I see started in 2013 to use PDF Engine side by side to PS 3 in their Color (production level) e.g. XJ75
Cheers
Adam.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
It is totally irrelevant what the raw input is to the VDP packages (such as XMPie, Darwin, DirectSmile, etc.) ... "
XMpie , Darwin , DirectSmile  Are plugin to InDesign or QuarkXpress  !
What I meant was VDP print applications which were built using famous packages like PlanetPress , Pres , Document Creation Server DCS ,  Lytrod , Elixir  , VIPP
These packages deal with File system direct  such as hot folder or network folder where your hundreds , thousands or Millions of raw files  resided there or submitted directly for printing  e.g.  text , CSV or XML format
The output document might range from simple VDP job which is just page/font formatting with several forms merged up to highly complicated marketing document with personalization , conditional promotions and ad , different pages layout  etc  .
The Developers who are trained on the above mentioned Software packages will require more time/training, buy more software options to build the same output if the input stream  has changed from text to CSV or XML or to PDF !
- Incase of moving to Input PDF stream might cause problem as the software and feature doesn't allow you to create the expected output!
PlanetPress for example is having another product for PDF data stream !    some of those software packages mentioned do not support  (yet)  Input PDF ! Xerox VIPP and DCS !
This might be cumbersome or an obstacle to move to PDF/VT technology while if  PS 4 appeared  they would all love to upgrade
That's why it might be easier to tell the system application who is responsible for generating the data stream to maintain the output in  raw format to generate the desired output!
Cheers
Adam
Votes
Translate
Translate
Report
Report
