• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Powerpoint 2010 with Voiceover Presenter Publish has NO Audio
Contributor ,
Aug 07, 2013 Aug 07, 2013
Presenter 9
25 slides
Powerpoint 2010
When published there is no audio. At all.
TOPICS
Presenter
Views
1.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Hi
Can you please package the presentation using Adobe presenter and send it to mkalyanp@adobe.com
Mahesh
Votes
Translate
Translate
Report
Report
LEGEND ,
Aug 08, 2013 Aug 08, 2013
Make sure the Publish Audio check box is selected for the desired method of publishing Adobe Presenter > Settings > Presentation > Quality
Votes
Translate
Translate
Report
Report
Contributor ,
Thanks for the reminder. I had it checked all along. I even changed the quality in one of my tests.
The search continues. (I packaged it up, now to get it sent for analysis.)
Michael
Votes
Translate
Translate
Report
Report
New Here ,
Aug 29, 2013 Aug 29, 2013
I'm having the same issues.  No audio plays in presenter, either published files or previews.  When I just play the slideshow, everything plays fine.  Did you get a resolution on this?
Votes
Translate
Translate
Report
Report
LEGEND ,
Did you insert the audio in your presentation via PPT or Presenter? It sounds like you inserted it via PPT, which won't translate to Presenter. You should be able to go to the Insert Audio tool in Presenter and see a button for importing audio from PPT. See if that works for you.
Votes
Translate
Translate
Report
Report
New Here ,
In Presenter 9, there isn't an option to insert audio on the presenter tab, it's only available via Insert ribbon.  This problem appeared AFTER I optimized the file for sharing and compressed the media.  If I reinsert the audio, it works fine.  Ugh!  Deadline missed.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
The insert audio option is in the Audio section on the left side of the Presenter ribbon, and should look like this (called Import, I just used the wrong term):
https://ehelp.wiki.csupomona.edu/images/9/98/Presenter03.jpg
Glad the audio is working fine now though.
Votes
Translate
Translate
Report
Report
Resources
Help resources
