Unable to create font
Aug 7, 2013 6:02 PM
I keep getting this "Unable to create font" error when I have missing footage in the latest version of AE CC. Very annoying and won't go away.
Is this a known bug in the latest update (wasn't doing it previously) or do I have an incorrect setting somewhere? Is there a work around?
cheers
Pete
After Effects CC. OSX 10.8.4
    Aug 7, 2013 10:57 PM   in reply to third unkle
    Reinstall the Verdana and Tahoma fonts from Microsoft.
    Mylenium
    Aug 8, 2013 6:42 AM   in reply to third unkle
    third unkle wrote:
    why would I want to install Microsoft fonts when I'm on a Mac?
    Because it will most likely fix the problem?
    Aug 8, 2013 10:35 PM   in reply to third unkle
    Mmh, sounds odd... Works just fine on PC. If it's in any way related, it would mean that the italic version of the font is inaccessible. Do you use any font managers? On second thought it could also be that your Mac attempts to use anotehr font like Myriad or Helvetica, so check each and every font on your system...
    Mylenium
    Aug 8, 2013 11:43 PM   in reply to third unkle
    Disable Suitcase and see, if it works with the system's native font handling. The font manager could be interfering with font family grouping or otehr things.
    Mylenium
    Sep 16, 2013 5:49 AM   in reply to third unkle
    This was happening to me, but I upgraded Suitcase fusion to the latest release and cleaned the font caches from within Suitcase Fusion, restarted, problem solved
    Sep 26, 2013 7:42 AM   in reply to third unkle
    Found it, turned out (as Mylenium suggested) Myriad Pro is the font AE CC uses for the placeholder filename.
    Oct 31, 2013 7:36 PM   in reply to Oxi_23
    This bug is fixed in the After Effects CC (12.1) update:
    http://adobe.ly/AE_CC_12dot1_details
    Let us know how this works for when you've tried with the new update.
    Nov 1, 2013 8:29 AM   in reply to Todd_Kopriva
    Hi Todd,
    I just updated AE CC this morning and I got the Unable to load font "^0" "Helvetica Neue" error.  Didn't get that error until the update.  Need to use AE ASAP.  Thoughts?
    EDIT:  I'm not using any font management software, BTW.  All other Adobe CC apps open fine on OSX 10.8.5
    Dec 14, 2013 12:44 PM   in reply to KLTV8
    The Helvetica bug is fixed in the After Effects CC (12.2) update:
    http://adobe.ly/AE_CC_12dot2_details
