CF10 Update 11 error log problem
Aug 7, 2013 8:52 PM
Tags: #update #cf10 #coldfusion10
Since applying update 11 on CF10 \ColdFusion10\cfusion\logs\coldfusion-error.log reports this error in bold:
org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\\ColdFusion10\\cfusion\lib;C:\\ColdFusion10\\cfusion\jintegra\bin; C:\\ColdFusion10\\cfusion\jintegra\bin\international;C:\\ColdFusion10\ \cfusion\lib\oosdk\classes\win
org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["ajp-bio-8012"]
org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.23
org.apache.catalina.core.ApplicationContext log
INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 23.7-b01
java.lang.NullPointerException
at coldfusion.server.jrun4.metrics.SimpleLoadMetric.run(SimpleLoadMetric .java:157)
at coldfusion.scheduling.ThreadPool.run(ThreadPool.java:211)
at coldfusion.scheduling.WorkerThread.run(WorkerThread.java:71)
INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["ajp-bio-8012"]
com.adobe.coldfusion.launcher.Launcher run
INFO: Server startup in 20398 ms
With update 10 applied the same log file reports this way:
INFO: Server startup in 20056 ms
There is also this message frequently occurring in coldfusion-error.log since update 11
org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [CfmServlet] in context with path [/] threw exception [ROOT CAUSE:
java.lang.StackOverflowError
at coldfusion.runtime.NeoBodyContent.cfoutput(NeoBodyContent.java:121)
Is there a problem with update 11? Update 10 seems to perform better.
Thanks, Carl.
  • Anjaneai Srivastava
    Oct 17, 2011
    Aug 8, 2013 12:13 AM   in reply to carl type3
    Hi Carl,
    Thanks for the details of your log.
    Does this problem arise when you try to visit the Scheduled Task page.If yes, a possible cause could be the neo-cron.xml's curroption.
    Could you use a back up of this file, in case you have and reboot the server and verify.
    If above case is not applicable, could you please add some information about what causes this problem to occur.
    Anjaneai
    Aug 21, 2013 11:06 AM   in reply to carl type3
    Hi Carl
    First of all, it's an honour to reply you
    Carl, did you try to rollback to update 10 and remove the logs, so that when you apply the update 11 and then check the same in fresh logs?
    Though logs always have a timestamp however I believe it's worth a shot as you have tried the same. I did check the same at my end and not able to find out the same behavior.
    VJ
    Aug 29, 2013 1:17 PM   in reply to carl type3
    Hi Carl
    Sorry for the delayed response. Didn't get java.lang.NullPointerException at coldfusion.etc
    VJ
    Oct 24, 2013 8:13 AM   in reply to carl type3
    Carl,  i'm seeing this same issue on two of my clients' servers.  In each case they are running Windows 2003 32-bit.  I haven't noticed the same issue on multiple other servers all of which are running 64-bit Server 2008 or higher with 64-bit CF installed.
    Did you ever find a resolution to this?  Each time they reboot their web servers CF failed to start.  If you wait a little bit and try it again a little later it comes up.  Seems like it times out initially.
    Nov 12, 2013 12:13 PM   in reply to carl type3
    What is the level in the logging.properties (C:\ColdFusion10\cfusion\runtime\conf)?
    org.apache.catalina.core.ContainerBase.[Catalina].[localhost].level = INFO
    OR
    org.apache.catalina.core.ContainerBase.[Catalina].[localhost].level = WARN
    VJ
