Cross-references crash FrameMaker 11
Aug 12, 2013 1:51 PM
We recently upgraded from Tech Comm Suite 3.5 to 4.0 (with FrameMaker 11), in a Windows 7 environment.
We have had several instances--on different workstations with different people--of FrameMaker 11 crashing when people are trying to create a simple cross-reference.
In a typical situation, the person has successfully created one or two cross-references, and then FrameMaker completely and abruptly shuts down the next time the person tries to create one.
FrameMaker creates "recover" files when that happens.
Has anyone else seen this behavior, and do you know how to prevent it?
Thanks in advance!
Tim
    Aug 12, 2013 2:01 PM   in reply to TimLMun
    Yes, I ran into it too & the last FM 11 patch seemed to have stopped it from happening, but it now seems to have started back up again.
    PS – make sure that you send in your error logs after applying the latest patches
    Aug 19, 2013 8:33 AM   in reply to TimLMun
    This happened to me on Thursday - Aug 15 and I am running version 11.0.2.384.
    Aug 19, 2013 8:43 AM   in reply to Urthie2011
    I'm working with a member of Adobe TCS team to try and figure out what's causing this crash behaviour - so far we haven't narrowed it down yet. You can always tell it's about to happen when the xrefs panel doesn't fully screen out what's behind it - it looks like a graphics refresh is needed, but then it crashes. On a WinXP machine I get the FM crash message, followed by a Windows error message about the application addressing a section of memory that it seems to have an issue with. This extra message doesn't occur on a Win7 64bit machine.
    Keep sending in your error logs.
    Aug 20, 2013 11:48 AM   in reply to Jeff_Coatsworth
    I am really getting frustrated with this bug - the other issue is that FM doesn't ask you to send the crash file, so I don't know what to do with them.
    I am running Win7 64-bit and this is happening four or five times a day now.
    Aug 20, 2013 11:51 AM   in reply to Urthie2011
    Sure it does - it's right in the error message (it's in all of them) - send them to fmerror@adobe.com - the logs are in your C:\Users\user_name\AppData\Roaming\Adobe\FrameMaker\11\ folder
    Sep 12, 2013 8:00 AM   in reply to Jeff_Coatsworth
    Update on this situation:
    Adobe TCS Support had me move my project to my local c:\ drive to see if that had any impact on the error's occurence - so far it hasn't had any impact at all. I did manage to capture the error happening on a Captivate video that I've submitted to the tech rep, but I can't make it happen at will through any sequence of actions. It just seems to happen at random intervals when opening up the Cross-Refs panel to add an xref to another open document. I never seem to have more than 2 or 3 .fm docs open at once that I'm making links to, so it's not like I'm really stressing the system.
    Sep 12, 2013 8:05 AM   in reply to Jeff_Coatsworth
    I imagine you've not suppressed alert messages, that all files open without missing resource dialogs, and that the files otherwise Update Book without any error logs, yes?
    Seems odd, 'cause I haven't seen any behavior like that, and certainly the Fm11 book was xref'd to the hilt!
    Sep 13, 2013 8:33 AM   in reply to mattrsullivan
    @matt - I'm just working at the doc level and don't have any books open when all this goes south.
    I'm pretty sure I haven't turned off any alerts; I do normally run with the Console turned off (because I've got the SetPrint plugin & I don't need notification of that), but I'm trying it on now as an experiment to see if it has any impact. So far I haven't crashed with it turned on, but it's only been a day now. I'll report back if  I can pinpoint something.
    Just as a test, I did open the master book of books file and update it - no issues other than the expected busted links that I expected to find. Once they were fixed up, it all updated fine. So all clean that way at least.
    Sep 13, 2013 8:39 AM   in reply to Jeff_Coatsworth
    Yep, I don't think it's whether the alerts or console are on/off, rather that having the alerts/console hidden tends to mask the real issue.
    In my experience (and esp. with Fm linked to Rh projects) missing resources in an Fm project are the cause of the majority of crashes I hear about.
    I know you know all this, so I'm repeating for the sake of others that find this thread!
    Bottom line: Cleaning up shortcuts in fonts/graphics/xrefs solves a great many woes!
    Sep 15, 2013 11:12 PM   in reply to mattrsullivan
    I start the working day by visiting the forum, as there's always something to learn whether or not I'm tracking a particular question. Reading through this one – in case the powers that be ever get me FM11 – I'm puzzled by one thing: what do you mean by "shortcuts in fonts/graphics/xrefs"? My apologies if I'm mising something thunderingly obvious :-}
    Sep 16, 2013 7:08 AM   in reply to Niels Grundtvig Nielsen
    Hi Niels, sorry for my brevity in the last post...
    My point:
    • If you know that fonts are missing, you should fix the issue
    • If you know that cross-references are broken, you should fix the issue
    • If you know graphics are missing, you should fix the issue
    In my experience, an amazing amount of errors will resolve, if these things are corrected, rather than ignored or masked by setting your Fm preferences to suppress the alerts.
    Sep 23, 2013 5:47 AM   in reply to Jeff_Coatsworth
    Update on the error situation - moving the docs local didn't have any effect, nor has running with the FM Console turned on (it doesn't reveal any issues prior to the crash anyway). The Adobe Tech Support team is concluding it's something in my docs themselves that is tripping up. They started life back as FM9 docs and have been upgraded since then. That might be an issue.
    When I can find some time, I'm going to set up 2 or 3 fresh new FM11 dummy lorsum FM docs and start doing some xrefs between them to see if I can get it to crash again. If I can, then I'll submit them to the techs to take apart.
    Sep 23, 2013 7:23 AM   in reply to Jeff_Coatsworth
    Jeff, have you tried importing the source and destination docs into a new Fm file? That may eliminate the kruft causing your crash.
    Sep 23, 2013 7:31 AM   in reply to mattrsullivan
    I have not – thanks for the idea
    Oct 8, 2013 11:56 AM   in reply to Jeff_Coatsworth
    I can consistently reproduce this problem.
    1. Choose Insert Cross Reference
    2. Click in list of paragraphs
    3. Press Pg Dn on the keyboard.
    4. Crash
    Comments:
    a. Don't know if it also crashes in list of x-references
    b. My files are all converted (recently) from FM 7.0
    c. Using 11.0.0.380
    Oct 8, 2013 12:17 PM   in reply to Catherine Zidane
    @Catherine,
    Verified. I can get this to happen repeatedly in a new (or existing) file. It happens with either the PgUp or PgDn keys. The Home, End and arrow keys work OK.
    You should file a bug report at:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=6 3
    BTW, your FM version needs to be patched. The latest is 11.0.2.384.
    Oct 8, 2013 12:56 PM   in reply to Catherine Zidane
    @Catherine - excellent work! I'll pass the info along to the TCS team member I've been dealing with.
