RE: Adobe RGB 1998  VS  ProPhoto RGB
Aug 12, 2013 11:40 PM
Hello Everyone.
I have used the Adobe RGB 1998 Color Space for many years, and I have no problem with that.
What Is ProPhoto RGB ?
Is It better than Adobe RGB 1998 ?
    Aug 12, 2013 11:58 PM   in reply to animationlife
    ProPhoto RGB is just about the widest color space.  It's used by photographers.
    As some noted authors and celebrities like to put it, "ProPhoto RGB is the only color space real men use".
    However, because it is soooooo wide, it can give you all kinds of grief if you don't know exactly what you are doing.  It contains many, many, MANY more colors than you can see on any monitor, it even encompasses what can only be termed "theoretical colors" because they're outside the visible color range in the physical world.
    Don't even think of going there unless and until you have fully digested the classical treaties on the subjects of Color Theory and Color Management.
    Here are some illustrations that might help you understand what I mean.
    Aug 12, 2013 11:50 PM   in reply to animationlife
    You need to learn some basics about color management and color spaces (and bit depth) before any answer you get will make sense to you. Do you understand color space (working spaces in Photoshop)? Do you understand the differences between sRGB, Adobe RGB and ProPhoto RGB? Do you understand the differences between 8-bit and 16-bit bit depth? Those would be topics you would want to read up on. Google is your friend.
    As it stands, any answers won't mean much unless you have some basics under your belt.
    Aug 13, 2013 12:03 AM   in reply to animationlife
    As station_two pointed out that Color Space is large.
    When converting images from a large Color Space to a smaller one (for example when preparing an image to be CMYK printed commercially) the results can suffer especially when working in 8bit.
    This naturally falls under what station_two summed up with
    but I thought it might be worth pointing out right away.
    Edit: Had missed Jeff’s post that also referred to the bit depth.
    Aug 12, 2013 11:59 PM   in reply to Jeff Schewe
    Jeff Schewe wrote:
    …any answers won't mean much unless you have some basics under your belt…
    …especially if the answers contained the typos that have now been corrected in post #1.
    With a topic title like this, your thread is going to attract an awful lot of views in anticipation of the kind of answers you've been getting.
    Aug 13, 2013 10:21 PM   in reply to animationlife
    Glad that you know the differences in 8 vs 16-bit because if you are going to use ProPhoto RGB, you'll need to work on 16-bit images to avoid potential banding...
    The advantages of ProPhoto RGB is that it's the only color space that can contain all the colors your image can capture in raw and all the colors that todays wide gamut printers can print (ignoring CMYK for the moment). Both sRGB and Adobe RGB will clip colors your camera can capture and once clipped, they can not be added back...
    I encourage you to test ProPhoto RGB with some caveats…first off, no display can actually show the full gamut of PP RGB…the wide gamut displays can only approach about 98% of Adobe RGB so when working, you need need to be sensitive to the fact that some colors in PP RGB will not be visible on your display…and that leads to the second caveat, that you are working on a calibrated and profiled display…are you?
    The areas where PP RGB will contain more colors than Adobe RGB are in strong reds, oranges, greens & blues…if you images don't obtain those colors, you may well not see any actually differences in normal output…but test it out and get back to us...
    Aug 13, 2013 10:33 PM   in reply to animationlife
    animationlife wrote:
    …I know Adobe RGB has a wider range of colors, than sRGB, but most Browsers work better with sRGB…
    I hope I made it clear to you that I'm not concerned with images on the web.
    sRGB is the lowest-common denominator, that's why it works "better" when your standards are low.  Well, kind of…
    Aug 13, 2013 11:39 PM   in reply to Jeff Schewe
    Jeff and others,
    Feel free to correct me if I’m mistaken. I believe that ProPhotoRGB is best used as working color space, and AdobeRGB is wide enough for finished images. A benefit of using ProPhotoRGB is that you use global adjustments that take RGB intensity values beyond the AdobeRGB and then add local adjustments that bring the intensity values back to AdobeRGB gamut, without losing information in the process. For instance, if you want to increase contrast in almost-blown areas, such as snow or swan feathers, you can multiply the image with a copy of itself, and then locally brighten areas which are too dark. In a small gamut the multiplication process may result in clipping. On a couple of occasions I’ve sent my photos to an outside advertising agency, in ProPhoto space, and the results were horrible (severely lacking in contrast and saturation). Quite obviously the editor had simply assigned AdobeRGB space to the images without converting the number values. Now I distribute my photos in AdobeRGB (not in CMYK because the advertising agency places some text over the images and then converts the composition to CMYK).
    Regards, Antero
    Aug 14, 2013 12:04 AM   in reply to Antero52
    You really, REALLY don't want to pass ProPhoto RGB files off to others unless they pass an intelligence test..."Do you know what you are doing?" Do you know how to use color management?" "Do you know hot to use Convert to Profile?" Any answer other than a profound YES means I won't give thenm ProPhoto RGB images..
    For final file delivery to outside sources, Adobe RGB (or even sRGB) is far safer…but you can convert to those at the end of your editing without handing over PP RGB images. That's what I do. In the case f CMYK, I go from PP RGB to CMYK and if they want sRGB, I convert from the CMYK back to sRGB. Kinda sneaky...
    Aug 14, 2013 1:21 AM   in reply to Jeff Schewe
    Delivering CMYK images would mainly make sense if one knew which specific CMYK space they wil be reproduced in; in advertising one has to expect that an image may be used in different publications, for posters, billboards etc. so it is in my opinion generally not indicated to provide CMYK images.
    If somebody requests an image to be CMYK without specifying the CMYK space I tend to suspect that the person is not very knowledgable regarding print and related matters.
    Aug 14, 2013 2:11 AM   in reply to animationlife
    Raw files have no color space. That's why they're called raw.
    The color space selection on a camera menu only applies to the JPEG preview and in some models the live histogram (if it comes from the JPEG). The fact that on EOS bodies the filename prefix changes for CR2 files as well is just because they couldn't be bothered with extra code.
      When I shoot with my Canon 5D, I always shoot Raw, and The color space for my canon 5D is Adobe RGB. There is no ProPhoto RBG Color Space In my Canon 5d.
    Aug 14, 2013 8:10 AM   in reply to Antero52
    Antero52 wrote:
    Jeff and others,
    I disagree completely, antero.  I tried to explain it to you in the preceding posts, but obviously I failed.
    There are colors on ProPhoto RGB that good printers can print, but woyuld be clipped, discarded, wasted in Adobe RGB.
    You really, really need to read up on the subject of color management.
    Passing ProPhoto RGB images to someone who does not understand the implications is absolutely insane.  What were you thinking?  —No need to answer that, it's just an expression.
    Jan 11, 2014 4:28 AM   in reply to station_two
    From my perspective this thread is saying this; if you don't understand color management and how it works in Photoshop as explained in post #7 and beyond, which requires individual reading on the users part then don't touch ProPhotoRGB.
    If you do understand color mangement but the parties you pass the file to, don't understand color management, then only use AdobeRGB or the safest solution sRGB, which is why some programs only use sRGB, because it's the safest.
    If all parties are undrestanding of color management, then you may be able to use ProPhotoRGB without hesitation.  With regards to CYMK, I haven't needed to send anything to a professional print shop, so I'm in the dark with what color profile for CYMK to use, although soon I may have to.
    Jan 11, 2014 5:34 AM   in reply to StrongBeaver
    CMYK is generally best left to prepress, so it's always recommended that photographers submit RGB files for offset print. Repurposing for different press conditions should be done from the original RGB file to avoid troublesome CMYK to CMYK conversions.
    If you have direct instructions from the printer as to which CMYK profile to use it's a different matter (but the conversion itself should always be done as the very last step). Which one specifically depends on a lot of things, not the least where in the world you are. In the EU zone, ISO Coated v2 300% (eci) is currently more or less the industry standard for books, magazines and so on, and the safest choice. But note that it is not included in the Photoshop installallation, and has to be downloaded from ECI.
    Adobe RGB is a particularly good match for ISO Coated, it can usually be converted with little clipping (and sometimes none). So in Europe at least, Adobe RGB has become the de facto standard for submitting photographic material for offset print. A more specifically tailored RGB space called ECI RGB is in use here and there, but to my knowledge it hasn't gained much traction.
    A wide gamut monitor is very useful in this context, since it covers both Adobe RGB and ISO Coated (for all practical purposes). This means you can soft proof the file very reliably.
    Jan 11, 2014 8:42 AM   in reply to twenty_one
    What ISO is used for printing in North America that is the standard ?
    Jan 11, 2014 9:17 AM   in reply to StrongBeaver
    Frankly I don't know. US Web Coated (SWOP) is the Photoshop default, so I suppose that tends to get used automatically a lot. But don't assume anything, always ask.
    (BTW "Web" has nothing to do with the internet; it refers to printing from large rolls. As opposed to sheetfed).
  • Trevor Dennis
    May 24, 2010
    Jan 11, 2014 1:04 PM   in reply to twenty_one
    That's interesting and useful information.  So would you say artwork is better left in RGB when presented to professional printer, and what sort of person would that argument apply to?  I produce artwork for advertising posters, big banners etc., as well as for the internet.  I always do the CMYK conversion myself, but some printers are happy to recieve RGB artwork.
    What is your experience?  What do you work in?
    Jan 11, 2014 2:47 PM   in reply to animationlife
    Actually, if you are sending out CMYK files, I sugggest to DON'T convert to Adobe RGB before RGB>CMYK because you are loosing the benefit of the larger PPRGB when you convert down to ARGB...
    Jan 11, 2014 3:15 PM   in reply to Trevor Dennis
    I suppose it depends on the nature of the business. What I do usually ends up in an InDesign file, and photos stay in Adobe RGB throughout, until press-ready PDF export.
    We outsource "heavy" design work to an agency, and they specifically want photographic material (which I usually supply) in Adobe RGB, because they may need to make last minute changes. We also produce a lot of stuff in-house, in which case we send CMYK directly to a printer. But the basic procedure is the same - Adobe RGB placed in an InDesign file, converted on export. We usually get a PDF job options file from the printer, which specifies not only CMYK profile but also all other PDF export settings.
    Knowing the target CMYK, I soft proof the material, but it stays RGB.
    In general CMYK is a can of worms. Total ink limit, overprint and knock-out issues, there are many potential stumbling blocks. I've scr**ed up more times than I like to think about, but you learn as you go along...
    Jan 11, 2014 3:44 PM   in reply to twenty_one
    I should add that I'm one of the apparently few who aren't too concerned with the gamut limitations of Adobe RGB vs. ProPhoto. I know it's there, of course, but I actually prefer to work in Adobe RGB whenever I can. The reason is that ProPhoto is so compressed in the shadows that I find it difficult to do subtle adjustments without spilling the whole can, so to speak. Just a matter of taste.
    At the same time I hate clipping on principle and go to great lengths to avoid it. So it's a rock and a hard place...
    But as for the finished result, it's my philosophy that if pressed, I could do whatever I want inside sRGB. It's not the absolute saturation as such, it's the relationship between colors that give an impression of rich color. And that's final
    I'll stop rambling and go to bed now.
    Jan 11, 2014 8:59 PM   in reply to animationlife
    Depends on the printer...the current Epson/Canon/HP 10-12 color ink jet printers can print colors that fall outside of Adobe RGB. So, yes, it can make a difference...
    Feb 28, 2014 9:23 PM   in reply to Jeff Schewe
    Dear Mr. Schewe,
    I am very interested in making my master file images in PP RGB, but need more information on the subject.
    Regarding the knowledge base for this discussion, do you think the book Real World Color Management, by the late great Bruce Fraser is still a relevant source, or is there something more updated I should look into?
    P.S. I know you and Mr. Fraser were lose friends, and I am so sorry for his untimely passing.
    Thank you very much,
    Don Chalfy
    Feb 28, 2014 11:45 PM   in reply to dchalfy
    The book is still a good reference on most things.
    Some applications and OSes have changed a bit since then, but color management has not chagned significantly.
    Mar 1, 2014 6:53 PM   in reply to Chris Cox
    Thank you Chris, I appreciate the feedback.
    Mar 15, 2014 7:25 PM   in reply to dchalfy
    Having read through this whole thread, I notice that it bounces back and forth between Lab and Printing Press/Advertising printing. As has been discussed, the print press guys change the color space to CYMK (which I believe should always be left to them as the presses are all so different and minor adjustments can cause major differences in the final alignment of the colors), but do professional Photo Labs (Bay Photo, Nations Photo Lab, MPIX...) ever change the color space or prefer a certain color space. I assume that the really good labs have very experienced print makers, so they can handle whatever is thrown at them. Just want to make sure those reading this thread realize that there are two different kinds of print houses, and that they do very different things with the files.
    Dan
