Getting error msvcp110d.dll
Aug 14, 2013 8:33 AM
Tags: #illustrator #adobe
hi all,
I took one of the sample program (EmptyPanel) from the adobe illustrator SDK.,
and build this in debug/release mode in Visual studio 2012.
but i am facing  error "MSVCP110d.dll is missing"    while using this plugin in different machine where VS2012 is not installed.
but in my current machine where i build this plugin .Its working fine.
can u suggest some thing to me please ?
Regards
ashish
    Aug 15, 2013 8:05 AM   in reply to 2007ay
    Hi Ashish,
    AI SDK CC is not compatible with VS 2012. All samples are designed for use with VS 2010.
    Alex
    (SDK Team)
    Aug 16, 2013 1:55 AM   in reply to 2007ay
    Hi Ashish,
    Try compiling the plugin for release rather than debug and see if that works.
    Regards,
    Alex
    Aug 16, 2013 2:21 AM   in reply to 2007ay
    Hi Ashish,
    Can you tell me what version of Windows you are using on both machines? Did you make any changes to the EmptyPanel plugin?
    Also, is this definitely for CC version of Illustrator?
    Alex
    Aug 16, 2013 5:02 AM   in reply to 2007ay
    Hi Ashish,
    This error usually suggests that you are trying to load a debug version of a plugin into a release version of AI. Can you make sure there are no traces of the debug version of the plugin left in your plugin folder?
    Failing that, is there any other error messages you're getting before/after that one?
    Alex
    Aug 16, 2013 6:00 AM   in reply to 2007ay
    I guess you're trying to launch Illustrator directly instead from Visual Studio.
    I would recommend to find a good book about how to use Visual Studio.
    Regards
    Bartek
    Aug 19, 2013 3:24 AM   in reply to 2007ay
    No. If for some reasond he/she doesnt have installed runtime libraries for vc100 then they need just redistibutables.
