Fuel666
Exporters - Tab question
Aug 16, 2013 5:42 AM
Tags: #tabs #exporter_api
Hi!
Two questions about tabs in the exporter UI:
Is it possible to hide a tab in the exporter UI?
..or to reorder tabs in UI?
Cheers
Chris
    Aug 16, 2013 10:27 AM   in reply to Fuel666
    as per the docs you can force a tab prior to the video & audio if you make it the Multiplexer keyword.
    Other than that there is no greater control - and per my experience there is no .hidden functionality.
    So I guess the answer is no - but I wish it were yes for better functionality.
    Aug 19, 2013 10:12 AM   in reply to Fuel666
    The Caption tab allows you to create sidecar caption files, even if direct embedding is not supported.
    Does the format you'll be supporting in your exporter not make sense to ever pair with captions?
    Aug 19, 2013 1:48 PM   in reply to Fuel666
    But sidecar files can still be created using these settings even if the exporter doesn't have any built-in caption support.  Is the format completely separate from the notion of captions?  It would clarify things to know what format you're writing an exporter for.
    Aug 28, 2013 10:19 AM   in reply to Fuel666
    Fuel666 wrote:
    I think it is a bit confusing for the user to have a Captions tab and a Subtitle tab.
    Agreed but I don't think there is a work around.
    It's the same issue as not being able to hide the FTP tab.
    Aug 28, 2013 10:22 AM   in reply to Rallymax-forum
    oh I just thought of something - granted very hacky...
    If you look at the presets file you'll be able to see what the parameter id is for the Caption elements.
    Based on that you could reprogram how they are drawn and do a rebuild of the GUI on every call to exPostProcessing.
    I don't know if it'll work to modify the Captions tab elements but if it does work you can move the DCP subtitles functionality there - which is where it belongs anyhow.
    Aug 28, 2013 2:50 PM   in reply to Rallymax-forum
    Is that something you'd use in your exporter Edward - to be able to hide the FTP tab?
    Yes, I agree this would need to be a feature request.
    Aug 28, 2013 3:01 PM   in reply to Zac Lam
    no, it was just a theory.
    I leave the FTP tab there on x264pro
