Elizabeth B65
trying to export/share in a format readable by Powerpoint2010 when insert video
Aug 17, 2013 1:36 PM
Tags: #wmv
Using Premier 11 Elements...... I'm trying to export/ share videos to my computer, then trying to insert them into a Powerpoint slide. It works fine if I use a raw WMV format straight from the camera, but they need editting. I'm doing the editing enhancing sound etc in Premier11 Elements, but when I "share' I can't find how to save as a .wmv format??
When I choose Share>Computer>  I end up with MP4 files or XMPSES files... all will not function when inserted into Powerpoint. I get a message "media unavailable" after pasted. Or sometimes the message "Powerpoint cannot insert" this file format.
How do I export as a .wmv?? the help info available says Premier 11 elements should do this!?
thanks for any help you can give, I'm new to this and under a time crunch for work.
    Aug 17, 2013 1:47 PM   in reply to Elizabeth B65
    Elizabeth B65
    If you are looking for an .wmv export in Premiere Elements 11 Windows, I suspect that you are missing the Windows Media choice because you are not scrolling down far enough under Publish+Share/Computer. The options there are:
    Adobe Flash Video
    MPEG
    AVCHD
    AVI
    Windows Media
    QuickTime
    Audio
    Look to the right of the listing. There is a scroll bar (of sorts) there.
    What video formats does your PowerPoint support? I just remembered. I have PowerPoint 2010. I will take a first look at that.
    If you need more detailed information on any of the above (or anything else in your Premiere Elements workflow), please do not hesitate to ask, but give details.
    Example: frame size and such.
    We will be watching for your follow up.
    Thanks.
    ATR
    Aug 17, 2013 1:55 PM   in reply to Elizabeth B65
    Elizabeth B65
    Looks like best to try for the wmv video for your PowerPoint 2010.
    I tried an AVCHD.mp4 (1920 x 1080 @ 29.97 progressive frames per second) into PowerPoint 2010 and got a "64 bit codec" error which lead me to this online article
    http://support.microsoft.com/kb/982954
    Let me know the frame size, frame rate, and any other requirements that you have for this wmv video destined for your PowerPoint 2010 project, and I will post specific settings suggestions for
    Publish+Share
    Computer
    Windows Media Player
    More later.
    ATR
    Aug 17, 2013 3:27 PM   in reply to Elizabeth B65
    Elizabeth B65
    Thanks for the great news. Glad the suggestions worked for you.
    If you want to take your Premiere Elements 11 Expert workspace Timeline to the 1920 x 1080 .wmv file for PowerPoint, the export from the following should insert into your PowerPoint 2010 nicely:
    Publish+Share
    Computer
    Windows Media
    with Presets = 720 x 480 16x9 29.97
    Then under the Advanced Button/Video Tab, the essentials are:
    Video codec = Windows Media Video 9
    Encoding passes = Two
    Bitrate Mode = Variable Unconstrained
    Frame Width = 1920 pixels
    Frame Height = 1080 pixels
    Frame Rate = 29.97 frames per second
    Pixel Aspect Ratio = Square Pixels (1.0)
    The default "Average Video Bitrate" appears to be 1500 Kbps (kilobits per second). You can experiment with that later if necessary, finding the compromise between Bitrate, quality, and file size.
    By the way, the installation of QuickTime is a requirement for working with Premiere Elements. The first sign of its absence is its presets missing from the Publish+Share/Computer/QuickTime. Typically the program requires being run Run As Administrator or from a User Account with Administrative Privileges.
    Please let us know how else we might help.
    Thanks.
    ATR
    Aug 17, 2013 6:21 PM   in reply to Elizabeth B65
    Elizabeth B65
    Thanks for the update.
    Please never hesitate to ask questions, small or big. Any question for which you do not have an answer is an important question.
    ATR
