Jules Helm
MultCam Clip Property Changes
Aug 17, 2013 2:57 PM
I did a multi-cam edit at 1280 x 720, then was given the original 1440 x 1080 footage. Great! Now I thought this would be a simple fix by replacing the low quality footage, with Higher Res footage on the hard drive folder.  That was successful.T hen create a new Sequence at 1440x1080 and copy the multi sync edit from the 720 sequence window, to the new 1080 sequence window. This worked only to a point, it brought in the new footage in, but the multi-sync clip original properties left a 720 border around the edge therefore clipping the HD footage. Is there a way to change the properties of the multi-sync clip to reflect the larger size and therefore remove the current big black border this is clipping the image.  Thanks for any insight or suggestions!
    Aug 17, 2013 3:58 PM   in reply to Jules Helm
    You'd have to change the original sequence containing the clips, not just the edited MC sequence.
    Aug 17, 2013 6:14 PM   in reply to Jules Helm
    Same as you did before.  Create the new correct sequence and copy/paste the clips.
    Aug 18, 2013 8:10 AM   in reply to Jules Helm
    Pay attention Jules.
    "Create the new correct sequence and copy/paste the clips."
    As the other thread is essentially the same problem, I've deleted it so we can keep all the data in one thread.
    Aug 18, 2013 4:02 PM   in reply to Jules Helm
    Tthat's the way it needs to be done.
