Judith Slaughter
How do I reduce font size on captions?
Aug 19, 2013 11:50 PM
I want to use captions on my slideshows but the font is far too large.   How do I reduce its size?  At present the captions are far too intrusive.  I am using PE9.
Judith
    Aug 20, 2013 12:35 PM   in reply to Judith Slaughter
    In the slide show editor, select a slide and then click on the caption text in the slide. On the right, you should see options to change the text formatting including size. You can also drag the text box to a new location on the slide.
    I am not aware of a global setting to change all the captions. Currently, the default size is variable, depending on the length of the text.
    Hope that helps
    Brian
