how do you reset the faders in the mixer panel in PPro CC
Aug 21, 2013 9:27 AM
how do you reset the faders in the mixer panel in PPro CC? I want to reset my channel faders and start my mix fresh but can find no way to reset them
  • Jon-M-Spear
    Jan 27, 2006
    Aug 21, 2013 9:33 AM   in reply to ron sussman
    It may be that you need to expand the audio track in the timeline, select to view volume keyframes and use the pen tool to select all the keyframes and delete them with the Del key on the keyboard.
    Aug 21, 2013 1:18 PM   in reply to ron sussman
    Just change them to 0.
    Aug 21, 2013 4:22 PM   in reply to ron sussman
    Dble Click / or right Click on the slider knob or the O
    One of those I think from memory.
    Correct.
    Aug 21, 2013 4:23 PM   in reply to ron sussman
    Do you want to reset the fader or remove keyframes?  Those are two different actions.
  • Jon-M-Spear
    Jan 27, 2006
    Aug 21, 2013 11:40 PM   in reply to Jim Simon
    Surely resetting the faders and removing the keyframes are one and the same!
    Aug 22, 2013 1:13 AM   in reply to Jon-M-Spear
    I know it won't help here but I might make a feature request. With the automated hardware consoles I have used they had a write to end button, you put the fader in write, set the level you wanted and pressed the write to end button and it wrote that level to the end of the sequence. It did it for all the automated parameters so you could do dynamics and eq as well as fader levels.
    Aug 22, 2013 4:46 AM   in reply to ron sussman
    OK, so just change them to 0, or double-click on them.
    Aug 22, 2013 4:48 AM   in reply to Jon-M-Spear
    Nooo...why would they be?  That'd be akin to removing the In/Out points of your clip in the Source Monitor also deleting the clip from your sequence.  It'd be disastrous and very much unwanted behavior.
  • Jon-M-Spear
    Jan 27, 2006
    Aug 22, 2013 5:27 AM   in reply to Jim Simon
    Well, if the OP means that he wants to undo the writing of audio levels to track ie, get rid of the keyframes  - ergo reset the faders, that's exactly what he must do.
    He does say that he wants to start the mix afresh!!
