mfmiller3000
Help with overprinting black
Aug 21, 2013 1:04 PM
Tags: #pre-press #prepress #overprinting
I've been reading about overprinting black, and while I know I should mark black type against a lighter backround as overprinting under Attributes, I'm getting confused about other areas that may need overprinting.
The project details are: Textbook is printed in C+K only. I'm creating graphics in Illustrator, applying overprinting to black areas (black is 100K only, as its two plates) sending to TIFF (project process, can't change at this point), and placing in InDesign, which produces the final pdfs.
Here's my question - should I be overprinting the black icons as well as the text in the circles? Should I be worried about the little white windows in the buildings in the central circle and the white dollar signs in the bottom circle? (If you can spot any other potential prepress issues with this, please advise! I'm a prepress newbie.)
Thanks so much for your help!!
    Aug 21, 2013 2:07 PM   in reply to mfmiller3000
    Without getting the actual file to inspect it is sometimes hard to say, but at first glance I would agree that setting all black objects you're talking about to overprint should be safe.
    As for the white objects you mentioned: Make sure they are not set to overprint.
    In general: Always check your files with View > Overprint Preview.
    Aug 21, 2013 2:23 PM   in reply to mfmiller3000
    Yes, do it.
    If you've got further questions just talk to your print provider.
    Aug 21, 2013 4:03 PM   in reply to mfmiller3000
    Remember that an overprinted black may sometimes show if it is printed over a partly-coloured background.
    In some cases it may be better to use the colour of the background plus 100% K than overprinting the black.
    Like this:
    I have deliberately desaturated the black to clarify my point, but this is well worth considering, especially when printing on soft papers.
    Aug 22, 2013 5:07 AM   in reply to mfmiller3000
    Basically yes.
    You might get away with a sort of average mixture of cyan and black.
    Don’t worry about paper stock to start with.
