ee_gary
AcroRd32 process hangs when launched from admin application; Win8, v11.0.03, Protected mode
Aug 21, 2013 3:41 PM
Tags: #protected_mode #windows_8 #adobe_reader_11 #adobe_reader_xi #run_as_administrator
AcroRd32 is called via Process.Start(ReleaseNotes) in the code snippet below.  On Windows 8, using Acrobat Reader v11.0.03, with Protected Mode enabled, and running as administrator (right click -> Run as Administrator), this spawns two AcroRd32 processes (sandbox + broker) that hang.  No PDF is displayed, no error dialog is shown, and subsequent attempts to display PDFs fail until the aforementioned processes are killed.  This is 100% repeatable.  Please note that it works as expected if using Windows 7 OR Acrobat Reader v10.1.4 OR Protected Mode disabled OR not running as administrator.
The pertinent portion of the Protected Mode log file is below:
[08:20/07:32:20] CreateProcessWAction: STATUS_ACCESS_DENIED
[08:20/07:32:20] app name: C:\Windows\system32\ctfmon.exe
[08:20/07:32:20] command line: ctfmon.exe
[08:20/07:32:20] Consider modifying policy using these policy rules: PROCESS_ALL_EXEC
[08:20/07:32:20] exe name: C:\Windows\system32\ctfmon.exe
Code snippet:
            // The name of the key must include a valid root.
            const string AdobeXI_ProtectedModeRegkey = "HKEY_CURRENT_USER\\Software\\Adobe\\Acrobat Reader\\11.0\\Privileged";
            const string ReleaseNotes = "C:\\Program Files (x86)\\Cypress\\PSoC Creator\\3.0\\PSoC Creator\\documentation\\release_notes.pdf";
            int IsAdobeProtectedMode = -1;
            try
IsAdobeProtectedMode = (int)Registry.GetValue(AdobeXI_ProtectedModeRegkey, "bProtectedMode", -1);
                if (IsAdobeProtectedMode == 1)
label2.Text = "ON";
else
// No protected mode
// Do nothing
label2.Text = "OFF";
            catch
                // No registry key exist
                // Do nothing
label2.Text = "No registry detected";
            if (bOpenRN == true)
Process.Start(ReleaseNotes);
    Aug 21, 2013 7:47 PM   in reply to ee_gary
    Easiest fix: disable Protected Mode.
    Aug 22, 2013 6:16 PM   in reply to ee_gary
    No, this is a user forum.  I'm sure the developers have known for a long time that Protected Mode is hopelessly broken, but so far there is no indication that they are ever going to fix it.  Disabling Protected Mode is a recommendation that I make about a dozen times every day in this forum.
    Reporting bugs or feature requests are done here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
