DAN28SY
how set image size open raw file?
Aug 21, 2013 5:33 PM
Tags: #image #size #raw #11 #editor #pse
How to set image size/resolution when opening a raw file in pse 11 editor??
win 7 pro; pse 11 settings: edit>preferences>print resolution = 337.596, screen resolution 109 dpi( 27 inch, dell U 2711). Originally print resoltuion was set to 240 dpi  but was changed in case this was causeing a problem. CRAW v 7.4.0.137
Camera alpha 65, image size is: 6000x3376 dpi; (83.33x46.88 inch)
Problem is: Currently when I edit a RAW file in CRAW and then open in pse editor image size is: 6000x3376 px; 25x14.667 inches at 240 dpi ( by ration this corresponds to:17.773x10 inch at 337.6 dpi)
I am trying to change settings so the raw file opens as: 17.776x10 and anywhere from240 to 337.6 dpi
whatever works or is esiest to set.
My settings are for use in creating blue ray dvd movies and with cropping and editing printing high quality pictures for family.
Thanks  in advance for any help you can provide.
    Aug 21, 2013 7:16 PM   in reply to DAN28SY
    That's a Sony Alpha SLT-A65?
    Are those pixel dimensions of 6000 x 3376 the size the camera raw files came out of the camera?
    You can't really change the resolution that the photoshop elements version of camera raw opens the the files into the pse 11 at.
    (i think 240 is the default for most cameras)
    You can however set the resolution with Image>Resize>Image Size if you need to for printing or other uses.
    In the Image size dialog uncheck Resample Image and enter the resolution.
    Aug 21, 2013 7:38 PM   in reply to DAN28SY
    That seems to be a ratio of around 16 to 9 (16:9) instead of 3 to 2.
    Did you crop the images before listing the pixel dimensions as 6000 x 3376?
    Aug 22, 2013 9:43 AM   in reply to DAN28SY
    May I suggest that even if you did go ahead and change the resolution in 1000 photos manually, there really is no point in doing so (if that's all you are doing is changing the resolution with "Resample Image" unchecked). Your image doesn't change if you do this, not a single pixel is different.
    You could save yourself a huge amount of time just by not doing it, and as far as I know, you lose nothing.
