Extension not loading (blank panel) - code signing issue?
Aug 22, 2013 9:11 AM
I have an issue with my Extension with Windows 8 and Photoshop CC. When I try to call the extension, the extensions panel pops up but keeps blank, then shortly after a dialog box shows "Cannot complete command because the extension could not be loaded".
  • I used EB 2.1 to build the extension
  • I used a self made code signing certificate when building the .zxp
  • It installs fine with Extension Manager CC, just showing an alert because of the untrusted publisher (me)
  • With Windows 7 (and Photoshop CS6, I don't have CC there) it loads fine
By chance I discovered that the registry entry
"PlayerDebugMode"="1" in [HKEY_CURRENT_USER\Software\Adobe\CSXS.4]
helps the extension to load! Since that registry entry is claimed to "run unsigned extensions during development" (see EB docs), I wonder whether the loading error is an code signing issue showing up only with Photoshop CC (and Windows 8?).
Additionally, in the "csxs4-PHXS.log" I found the line
2013-08-22 14:09:38 : INFO  Return value of PlugPlugLoadExtension call : PlugPlugErrorCode_invalidSignature
which seems to approve my assumption.
Does this mean, that I need a valid (trusted, non self made) code certificate to deploy my extension for Photoshop CC (and later)?
Any help is very appreciated!
    Aug 27, 2013 8:29 AM   in reply to szerner
    I had the same problem. The manifest editor created an invalid path to the swf.
    I edited the xml to change the swf path from "./" to "../" and the screen is no longer blank.
    Hope this helps.
    -M
    Aug 27, 2013 10:08 AM   in reply to szerner
    If you create an mxi file you can convert it to a zxp or just use the cert that Adobe Exchange Packager creates. To download Adobe Exchange Packager sign in with your Adobe ID here:
    http://adobeexchange.com/producer
    Then go to Resources. Packager might be able to help...
