What is this Frame file:  xxxx.fm.OFF ?
Aug 23, 2013 1:59 PM
Tags: #framemaker_11
This file appeared in my doc folder on 8/9. (I replaced the file name itself with xxxx.)
xxxx.fm.OFF
What is it? Can I delete it?
Thanks!
D
    Aug 27, 2013 5:50 AM   in reply to ddb
    What version of Frame?
    If the file isn't zero-length, what is in it? Try opening with a plain text editor.
    I've never seen a file of that name in FM 3.1 through 7.1, not in my limited use of FM9.
    Aug 27, 2013 10:11 AM   in reply to Error7103
    The three-character suffix is actually a hex value in the range 000 to FFF. This is a temporary file that FM writes during various processes (such as Autosave). It first creates the file with the odd suffix (i.e. xxxx.fm.0FF), and when it completes the writing task, it deletes the specific .fm version and then renames the odd suffix (i.e. xxxxx.fm.0FF) version to the .fm version it is replacing.
    If there are any issues (network, file space, phase of the moon, etc.) during this three-step shuffle, FM may not be able to complete the save of the final version. FM then typically issues a warning message: "The document was saved to a temporary file, but FrameMaker cannot rename it to have the correct name. The newer version has an odd suffix."
    If it's an old file, then you can delete it. However, if it's very recent, then it *may* contain edits that didn't make it to your file.
