Ddembessa
What is the html code to show Flash Skin control on website?
Aug 24, 2013 1:02 AM
I create a video using Abdoe Flash Proffesional CC, the Flash skin shows very well on my local pc, but does not show up the website.
I need help.
This is the html code created by the software which I loaded in my web server:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w
video plays well and show 3.org/1999/xhtml" lang="en" xml:lang="en">
          <head>
                    <title>vopviu</title>
                    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                    <script type="text/javascript" src="swfobject.js"></script>
                              <!-- Adobe recommends that developers use SWFObject2 for Flash Player detection. -->
                              <!-- For more information see the SWFObject page at Google code (http://code.google.com/p/swfobject/). -->
                              <!-- Information is also available on the Adobe Developer Connection Under Detecting Flash Player versions and embedding SWF files with SWFObject 2" -->
                              <!-- Set to minimum required Flash Player version or 0 for no version detection -->
                              var swfVersionStr = "11.1.0";
                              <!-- xiSwfUrlStr can be used to define an express installer SWF. -->
                              var xiSwfUrlStr = "";
                              var flashvars = {};
                              var params = {};
                              params.quality = "high";
                              params.bgcolor = "#ffffff";
                              params.play = "true";
                              params.loop = "true";
                              params.wmode = "transparent";
                              params.scale = "showall";
                              params.menu = "true";
                              params.devicefont = "false";
                              params.salign = "";
                              params.allowscriptaccess = "sameDomain";
                              params.allowFullScreen = "true";
                              var attributes = {};
                              attributes.id = "vopviu";
                              attributes.name = "vopviu";
                              attributes.align = "middle";
                              swfobject.createCSS("html", "height:100%; background-color: #ffffff;");
                              swfobject.createCSS("body", "margin:0; padding:0; overflow:hidden; height:100%;");
                              swfobject.embedSWF(
                                        "vopviu.swf", "flashContent",
                                        "750", "600",
                                        swfVersionStr, xiSwfUrlStr,
                                        flashvars, params, attributes);
                    </script>
          </head>
          <body>
                    <!-- SWFObject's dynamic embed method replaces this alternative HTML content for Flash content when enough JavaScript and Flash plug-in support is available. -->
                    <div id="flashContent">
                              <a href="http://www.adobe.com/go/getflash">
                                        <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.g if" alt="Get Adobe Flash player" />
                              </a>
                              <p>This page requires Flash Player version 11.1.0 or higher.</p>
                    </div>
          </body>
</html>
Thanks.
    Aug 24, 2013 5:11 AM   in reply to Ddembessa
    If you are using the FLVPlayback component, there should be an swf skin file for it that you need to upload to the server as well.
