Extract embedded fonts from pdf
Aug 25, 2013 8:06 AM
Tags: #pdf
Please i want to ask about the ability to extract embedded fonts from pdf is easy or not? because i tried to extract fonts form specific pdfs but there are fonts that not valid files, why these files not valid? are there specific technique to extract fonts from pdf?
    Aug 25, 2013 9:57 AM   in reply to baccah
    Fonts inside a PDF aren't required to be "OS installable" fonts – in fact the vast majority (>90%) will not be, as most of the information that isn't needed by PDF (but would be to use the font in other environments) has been removed to save space.
    Aug 26, 2013 2:36 AM   in reply to baccah
    Each font has its own licensing terms. Certainly, if you extract fonts from PDF files and install them in the local system, it will often break those license terms.
    Many fonts have "embedding licenses". These allow you to own a font, and embed it in a PDF, to be viewed on other systems; the same license doesn't allow it to be shared with other systems for any other use.
    So, since extracting the fonts would often break the license, the best advice is: if you want to use the same font as found in a PDF, just buy it... and hope it will be recognised as the same font, because it often is not.
    Aug 26, 2013 4:06 AM   in reply to baccah
    Technically: don't know. If they just extract the font streams unmodified, unlikely to be of much use. Most fonts are subset so they are no use.
    Legally: check the font license. Yes, each single individual font has a different license. The easiest way to avoid issues and endless checking is to not think about using them from a PDF.
    Aug 26, 2013 7:43 AM   in reply to baccah
    It reflects what you have already been told – that fonts in PDF are NOT usable outside of PDF.
    Aug 27, 2013 2:09 AM   in reply to baccah
    Very simple, and you suggested it in reply #2. If you want to use a font, BUY IT.
