Simple Cross Dissolve Doesn't Work
Aug 25, 2013 3:46 PM
Tags: #transition #mp4 #dissolve #cross_dissolve
Hi, I am relatively new to Premiere CC, so forgive me if this is a simple fix. I've been searching forums for hours trying to find out why I can't get my simple cross dissolve to work.
I am trying to put a transition between two .mp4 clips, but instead of putting in a transition of decent length, Premiere makes a TINY one (1-2 frames) and then doesn't let me change its duration by dragging. If I manually change the duration by typing it in, it does expand the transition, but with lines through the timeline element (as if I was applying it to a clip without handles). I have confirmed that I have handles, and that the transition works on any other cilps.
I've spent more than two hours trying to get something to work that should take less than 10 seconds. Any help is appreciated.
    Aug 25, 2013 4:35 PM   in reply to nathanoday
    Open the problem transition in the Effect Controls with timeline view and make a screendump and post it here on the forum.
    Aug 26, 2013 7:32 PM   in reply to nathanoday
    It would seem they're not long enough.  You need half the desired transition duration for each clip.
    Sep 15, 2013 3:21 PM   in reply to nathanoday
    Place your clips in the same Vidoe track.'
    Seems like you might have A / B'd them ....but a Timeline grab would show us.
  • joe bloe premiere
    Dec 6, 2009
    Sep 15, 2013 3:43 PM   in reply to nathanoday
    All looks fine to me.
    Wondering if MP4 into MPEG is an issue due to GOP issues. Just a wild guess.
  • joe bloe premiere
    Dec 6, 2009
    Sep 15, 2013 4:20 PM   in reply to nathanoday
    That's the concept!
    You gotta have the available frames to
    accommodate the length of the transition.
    note:
    As shooternz (I think) meant by A / B would be having the two clips
    on different tracks... if you do that, the idea of needing 'handles' for your
    transitions is more visibly apparent.
  • joe bloe premiere
    Dec 6, 2009
    Sep 15, 2013 4:25 PM   in reply to nathanoday
    Lookie here:
